Learn how to integrate Razor Pay with GoTo Webinar using Pabbly Connect to automate your payment and registration process seamlessly. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To begin integrating Razor Pay with GoTo Webinar, first, access Pabbly Connect. This automation platform allows you to create workflows between various applications seamlessly. Sign in to your Pabbly Connect account or create a new one if you’re a first-time user.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, you can start building your integration workflow. Follow the steps to create an automation that connects Razor Pay and GoTo Webinar, ensuring a smooth registration process for your webinar attendees.
Creating a workflow in Pabbly Connect is essential for automating your processes. Click on the ‘Create Workflow’ button at the top right corner of the dashboard. You will be prompted to name your workflow, for example, ‘Create GoTo Webinar Registrant on Razor Pay Payment.’ Select a folder to organize your workflows.
  • Choose a folder for better organization.
This action sets the stage for the automation process, where you will define triggers and actions to connect Razor Pay with GoTo Webinar.
Once your workflow is created, the next step is to set up the trigger. In this case, select Razor Pay as your trigger application. This integration will be triggered when a new payment is captured through Razor Pay. Choose the trigger event as ‘Payment Captured’ to initiate the workflow. using Pabbly Connect
After selecting the trigger event, Pabbly Connect will provide you with a webhook URL. This URL is crucial as it connects Razor Pay to your Pabbly Connect workflow. Copy this webhook URL, as you will need it to set up the Razor Pay integration.
  • Select Razor Pay as the trigger application.
  • Choose ‘Payment Captured’ as the trigger event.
This setup ensures that every time a payment is processed through Razor Pay, your workflow in Pabbly Connect will be activated, allowing for seamless registration in GoTo Webinar.
4. Configuring Razor Pay to Work with Pabbly Connect
Now that you have your webhook URL, it’s time to configure Razor Pay. Log into your Razor Pay account and navigate to the ‘Account and Settings’ section. From there, go to ‘Website and App Settings’ and select the ‘Webhooks’ tab. using Pabbly Connect
Click on the ‘Add New Webhook’ button and paste the copied webhook URL into the designated field. Select the event type as ‘Payment Captured’ to ensure Razor Pay sends data to Pabbly Connect whenever a payment is made. Save your webhook configuration to establish the connection.
This integration allows Pabbly Connect to receive real-time updates from Razor Pay, ensuring that your GoTo Webinar registrations are automatically updated when payments are received. With this setup, you can streamline your payment and registration process effectively.
5. Connecting GoTo Webinar with Pabbly Connect
The final step in this automation process is connecting GoTo Webinar to Pabbly Connect. In your workflow, select GoTo Webinar as the action application. Choose the action event as ‘Create Registrant’ to automatically register attendees who have completed their payment.
During the setup, you will need to map the data received from Razor Pay to the corresponding fields in GoTo Webinar. This includes first name, last name, email address, and any other required information. By mapping this data, you ensure that every registrant’s information is accurately captured in your GoTo Webinar account.
Select GoTo Webinar as the action application. Choose ‘Create Registrant’ as the action event. Map the data fields from Razor Pay to GoTo Webinar.
Once you’ve completed these steps, save your workflow. Now, every time a payment is made through Razor Pay, a new registrant will be automatically created in your GoTo Webinar account, enhancing your webinar management process.
By following these steps, you can effectively integrate Razor Pay with GoTo Webinar using Pabbly Connect. This automation streamlines the registration process for your webinars, ensuring that every attendee who makes a payment is automatically registered. Enjoy the efficiency and ease that comes with using Pabbly Connect for your business needs.
