Learn how to integrate Razer Pay and Zoho Campaigns using Pabbly Connect. Follow our step-by-step tutorial to automate subscriber updates efficiently. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To begin the integration process, you need to access Pabbly Connect. This powerful automation tool allows you to connect various applications seamlessly. Start by visiting the Pabbly Connect website and signing into your account. If you’re a new user, you can sign up for free and enjoy 100 free tasks each month.
Once logged in, you will see the dashboard displaying all available applications. Click on the ‘Access Now’ button to enter the Pabbly Connect dashboard. Here, you can create workflows that automate tasks between Razer Pay and Zoho Campaigns, streamlining your business processes.
Next, you need to create a workflow to connect Razer Pay with Zoho Campaigns using Pabbly Connect. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard. A dialog box will appear, prompting you to name your workflow and select a folder to save it in.
- Name your workflow: ‘Add or Update Zoho Campaign Subscriber on Razer Pay Payment’.
- Select the folder: Choose ‘Razer Pay Automations’.
After filling in the details, click the ‘Create’ button to finalize your workflow. This creates a new workflow that will be used to automate subscriber updates whenever a payment is made through Razer Pay.
Now, it’s time to set up the trigger for your workflow using Pabbly Connect. The trigger is essential as it determines when the automation will start. Select Razer Pay as the trigger application and choose the event as ‘Payment Captured’. This means that whenever a new payment is successfully made, the trigger will activate.
To connect Razer Pay to Pabbly Connect, you will need to copy the provided webhook URL. Go to your Razer Pay account settings and navigate to the ‘Webhooks’ section. Here, paste the copied URL and select the active event as ‘Payment Captured’ before clicking on the ‘Create Webhook’ button.
After setting up the webhook, go back to your Pabbly Connect workflow. It should now show that it is waiting for a webhook response, indicating that the connection has been established successfully.
4. Performing a Test Payment
To ensure that everything is set up correctly, you will need to perform a test payment using Razer Pay. This step is crucial as it verifies that Pabbly Connect can capture the payment details correctly. Go to your payment page in Razer Pay and fill in the required information for a test transaction.
- Enter customer details: First name, last name, email, phone number, and address.
- Select payment method and complete the payment.
Once the payment is processed, return to your Pabbly Connect workflow to check if the response from the test payment has been captured. You should see all relevant payment details populated in the trigger section, confirming that the integration is working as intended.
5. Setting Up the Action to Update Zoho Campaigns
After confirming that the trigger is working, it’s time to set up the action step in your workflow using Pabbly Connect. Select Zoho Campaigns as the action application and choose the event ‘Add/Update Subscriber’. This action will automatically add the customer as a subscriber in your Zoho Campaigns account whenever a payment is captured.
Next, connect your Zoho Campaigns account by entering the domain for your Zoho account. After authorization, select the list where you want to add the subscriber. Map the relevant fields from the payment response to ensure that the right data is sent to Zoho Campaigns.
Once you’ve mapped all necessary fields, click the ‘Save & Send Test Request’ button. A confirmation email will be sent to the customer, and upon confirmation, they will be added to your Zoho Campaigns subscriber list. This completes the integration process, allowing you to automate subscriber updates efficiently.
In this tutorial, we explored how to integrate Razer Pay with Zoho Campaigns using Pabbly Connect. By automating subscriber updates, you can save time and enhance customer engagement with timely communications. This integration allows for seamless management of your customer database, ensuring you never miss an opportunity to connect with your audience.
