Learn how to integrate Razer Pay with Keep using Pabbly Connect to automate contact creation with every payment. Follow our detailed tutorial for seamless integration.
To start integrating Razer Pay with Keep, first, you need to access Pabbly Connect. This platform allows you to automate processes between your applications seamlessly. Visit the Pabbly Connect homepage and either sign in or create a new account.
Once logged in, you will be directed to the dashboard. Here, you can begin creating your workflow. To do this, click on the ‘Create Workflow’ button located at the top right corner. You will be prompted to name your workflow, which should reflect its purpose, such as ‘Create Keep Contact on Razer Pay Payment.’
2. Setting Up the Trigger with Razer Pay
In this section, you will set up the trigger for your workflow using Razer Pay. A trigger in Pabbly Connect is the event that starts your automation. Select Razer Pay as your trigger application and choose the event as ‘Payment Captured.’ This means the workflow will activate whenever a payment is successfully captured.
- Select ‘Razer Pay’ as the trigger application.
- Choose ‘Payment Captured’ as the trigger event.
After copying the webhook URL, go to your Razer Pay dashboard. Navigate to the account settings and find the webhook settings option. Here, create a new webhook and paste the URL you copied from Pabbly Connect into the designated field. Select the event ‘Payment Captured’ to ensure that it triggers the workflow whenever a payment is processed.
3. Testing the Webhook Response
After setting up the webhook, it’s essential to test the connection. Go back to your Razer Pay payment page and perform a test payment. This step is crucial to ensure that Pabbly Connect receives the payment data correctly. Fill in the necessary details and complete the payment process.
- Enter dummy data for the payment.
- Select a payment method and complete the transaction.
- Check Pabbly Connect for a successful response from Razer Pay.
Once the payment is processed, return to Pabbly Connect to see if the workflow received the data. If successful, you will see the details of the payment, confirming that the integration is working correctly.
4. Filtering Payments for Keep Contacts
In this step, you will add a filter to ensure that only specific payments trigger the creation of contacts in Keep. This functionality is vital for managing your contacts effectively. In Pabbly Connect, add a new action step and select the filter option.
Choose the filter condition based on the product name. Set the filter to trigger only for the ‘Automation and AI Course’ payments. Save and test the filter to ensure it’s functioning correctly.
By setting this filter, you can streamline the process of creating contacts in Keep, ensuring that only relevant payments will result in new contacts. This step enhances the automation process, making it more efficient and tailored to your needs.
5. Creating Contacts in Keep Using Pabbly Connect
The final step is to create a new contact in your Keep account based on the payment details captured by Razer Pay. In this action step, select Keep as your application and choose the action event as ‘Create or Update a Contact.’ This action will ensure that every relevant payment results in a new contact entry.
Map the fields from the Razer Pay payment response to the corresponding fields in Keep. For instance, map the customer’s email, first name, last name, and phone number to the respective fields in Keep. This mapping allows Pabbly Connect to automatically fill in the contact details based on the payment data.
Once you have mapped all necessary fields, save the action and test it to confirm that a new contact is created in Keep. This finalizes the integration process, allowing you to efficiently manage your contacts and automate your follow-up communications.
In this tutorial, we demonstrated how to integrate Razer Pay with Keep using Pabbly Connect. By automating the contact creation process, you can save time and ensure that your students receive timely communications. This integration enhances your workflow and improves your efficiency in managing customer relationships.
