Learn how to integrate Razer Pay with Mailchimp using Pabbly Connect to automate member creation upon payment. Follow our detailed tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin integrating Razer Pay with Mailchimp, first, you need to access Pabbly Connect. This platform allows you to automate workflows between different applications seamlessly. If you are a new user, sign up for an account, which takes less than two minutes and offers 100 free tasks upon registration.
Once you log in to Pabbly Connect, navigate to the dashboard. On the right side, click on the ‘Create Workflow’ button to start setting up your integration. Name your workflow appropriately, such as ‘Create Member in Mailchimp for Razer Pay Payments’ and then click on create to proceed to the next step.
2. Setting Up the Trigger Event with Razer Pay
In this step, you will set up the trigger event that initiates the workflow. Select Razer Pay as your trigger application in Pabbly Connect. The event you want to choose is ‘Payment Captured’, which will activate the workflow every time a payment is successfully processed.
- Select Razer Pay as the trigger application.
- Choose ‘Payment Captured’ as the trigger event.
- Copy the provided webhook URL for integration.
After copying the webhook URL, navigate to your Razer Pay account. Go to Account and Settings, then find the Webhooks section. Paste the copied URL and select the ‘Payment Captured’ event to create the webhook. This setup allows Pabbly Connect to receive notifications every time a payment is made.
3. Testing the Webhook Integration
Once you have set up the webhook in Razer Pay, it’s time to test the integration. Go back to Pabbly Connect, where it will show that it is waiting for a webhook response. To initiate this, perform a test payment on Razer Pay.
Navigate to the payment page of the product you want to test, fill in the required details such as name, email, and payment information, and complete the transaction. After the payment is successful, return to Pabbly Connect to see if the webhook response has been recorded. You should see details like payment status, order ID, and user information.
4. Adding Member to Mailchimp with Pabbly Connect
With the webhook successfully tested, the next step is to add the user as a member in Mailchimp. In Pabbly Connect, set the action application to Mailchimp and select the ‘Add New Member with Custom Fields’ action. This allows you to map user data from the payment response to Mailchimp fields.
- Connect your Mailchimp account by providing the API key and data center.
- Map the user’s email, first name, last name, and any other relevant fields.
- Set the subscriber status to ‘Subscribed’.
After mapping the fields, save and test the action. If everything is set up correctly, you should see a confirmation that the member has been added to your Mailchimp audience. This completes the integration process, allowing new members to be automatically added upon payment.
5. Conclusion
In this tutorial, we demonstrated how to integrate Razer Pay and Mailchimp using Pabbly Connect. By following the steps outlined, you can automate member creation in Mailchimp every time a payment is captured. This integration enhances your marketing efforts and streamlines user management.
With Pabbly Connect, automating workflows between applications becomes simple and efficient. Start integrating your applications today to improve your business processes.
