Learn how to seamlessly integrate PayKickstart with SendPulse using Pabbly Connect for automatic subscriber management. Follow this step-by-step tutorial. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To begin the integration process using Pabbly Connect, first, type Pabbly.com in your browser. This will lead you to the Pabbly website where you can find various products.
Once on the site, hover over the ‘Products’ menu and select the option for ‘Connect.’ After clicking on ‘Connect,’ you can sign in or create a new account. Pabbly Connect allows you to automate workflows between applications without any coding knowledge.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button at the top right corner. You will need to name your workflow; for this integration, name it ‘PayKickstart to SendPulse’.
  • In the trigger app, select ‘PayKickstart’.
  • Choose the trigger event as ‘Subscription Created’.
After setting up the trigger, you will be prompted to connect your PayKickstart account. This allows Pabbly Connect to receive data from PayKickstart when a new subscription is created.
3. Setting Up PayKickstart for Webhook Integration
Next, navigate to your PayKickstart account and select the product you want to integrate. Go to the ‘Campaigns’ section and click on the product you wish to edit.
  • Scroll down to find the ‘Integrations’ option.
  • Paste the webhook URL into the ‘IPN URL’ field in PayKickstart.
Set the event to ‘Subscription Created’ and save your changes. This step ensures that any new subscription made in PayKickstart will trigger an action in Pabbly Connect.
4. Capturing the Webhook Response in Pabbly Connect
After setting up the webhook, return to Pabbly Connect and click on ‘Capture Webhook Response’. This action allows Pabbly to listen for incoming data from PayKickstart.
To test this, create a dummy subscription in PayKickstart. Fill in the required customer details and complete the purchase. Once the subscription is created, Pabbly Connect should capture the data, including the customer’s name, email, and subscription amount.
5. Adding a Subscriber to SendPulse
Now that Pabbly Connect has captured the necessary data, the next step is to add this subscriber to SendPulse. Click on the plus button in your workflow to add an action.
Select ‘SendPulse’ as the action app. Choose the action event ‘Add a Subscriber’. Connect your SendPulse account using your API ID and Secret.
Map the fields from the captured data to the corresponding fields in SendPulse, such as email and name. Once mapped, click on ‘Save’ to complete the integration. This will ensure that every new subscription in PayKickstart automatically adds a subscriber to SendPulse.
This tutorial demonstrates how to integrate PayKickstart with SendPulse using Pabbly Connect. By following the steps outlined, you can automate subscriber management efficiently, ensuring that every new subscription is captured and added seamlessly.
