Learn how to automate the integration between Pabbly Connect and Go High Level using Pabbly Connect in this detailed step-by-step guide. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start the integration process, access Pabbly Connect by typing Pabbly.com in your browser. Upon reaching the home page, you can either sign up for free or sign in if you are an existing user.
Once logged in, you will find the dashboard displaying all your workflows. To create a new workflow, click on the ‘Create Workflow’ button located in the right corner. Give your workflow a name, such as ‘Pabbly Form Builder to Go High Level,’ and then click on Create.
2. Setting Up the Trigger with Pabbly Form Builder
In this step, we will configure the trigger application which is Pabbly Form Builder. Select it as your trigger application and choose the ‘New Form Submission’ event. This will initiate the automation whenever a new form is submitted.
- Select ‘New Form Submission’ as the trigger event.
- Copy the provided webhook URL from Pabbly Connect.
- Open Pabbly Form Builder and navigate to Integrations.
- Create a new webhook and paste the copied URL.
After saving, your form will be set to wait for a webhook response. Next, you need to perform a test submission using the form you created in Pabbly Form Builder.
3. Creating the Form and Testing the Submission
In this section, we will create a simple form using Pabbly Form Builder. The form should include fields such as first name, last name, and email. After creating the form, click on ‘Save and Share’ to copy the form link.
Fill out the form with test data, such as:
- First Name: Test
- Last Name: Lead
- Email: [email protected]
After submitting the form, check back in Pabbly Connect to see if the response was captured successfully. You should see the response reflecting the details entered in the form.
4. Setting Up the Action to Create a New Contact
Now that we have the trigger set up, we can move on to the action step. In this step, we will select ‘Lead Connector’ (Go High Level) as our action application in Pabbly Connect. Choose the action event ‘Create Contact’ to add a new contact to your Go High Level CRM.
Click on connect and select ‘Add New Connection.’ Then log into your Go High Level account to establish the connection. After connecting, you will need to map the details from the form submission to the fields in the Go High Level contact form.
Map the First Name from the form submission. Map the Last Name accordingly. Map the Email as well.
Once you have mapped the fields, click on ‘Save and Send Test Request’ to verify the integration. Check your Go High Level account to confirm that the new contact was created successfully.
5. Summary of the Workflow Integration
In this workflow, we successfully integrated Pabbly Form Builder with Go High Level using Pabbly Connect. We started by setting up a trigger for new form submissions, followed by creating a form and testing it.
Next, we configured the action to create a new contact in Go High Level. After mapping the necessary fields and verifying the test request, we confirmed the successful creation of a new contact in the CRM.
This integration allows for seamless data transfer between Pabbly Form Builder and Go High Level, ensuring that all form submissions are automatically captured as contacts in your CRM.
In this tutorial, we explored how to automate the integration between Pabbly Form Builder and Go High Level using Pabbly Connect. This process enhances workflow efficiency and ensures accurate data management across platforms.
