Learn how to integrate Nish and ConvertKit using Pabbly Connect. Follow this detailed guide for seamless automation between your applications. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start integrating Nish and ConvertKit, first access Pabbly Connect. This platform allows seamless connections between various applications through automation. Visit the Pabbly Connect homepage and either sign in or sign up for a new account.
Once logged in, you’ll see the dashboard with various applications available for integration. Pabbly Connect is essential for creating workflows that automate tasks between Nish and ConvertKit, ensuring smooth operations without manual input.
To create a new workflow in Pabbly Connect, click on the ‘Create Workflow’ button located in the top right corner of the dashboard. You will then be prompted to name your workflow. For this integration, name it ‘Create User in Nish and Subscriber in ConvertKit from Webhook Response’.
  • Select the folder for your workflow, such as ‘Automations’.
  • Click the ‘Create’ button to finalize your workflow setup.
Your workflow will now be created, and you can proceed to set up the trigger and actions needed for the integration. Pabbly Connect will handle the automation process once configured correctly.
In this step, you will set up the trigger for your workflow using Pabbly Connect. Select ‘Webhook by Pabbly’ as your trigger application. This feature allows you to connect any application that is not natively integrated with Pabbly Connect.
Choose the trigger event as ‘Catch Webhook’. After selecting this, you will receive a webhook URL. Copy this URL as it will be used to connect your form created with Elementor to Pabbly Connect. This step ensures that every new form submission triggers the subsequent actions in your workflow.
4. Connecting Elementor Form to Pabbly Connect
Now, you need to connect your Elementor form to Pabbly Connect. Edit your form in Elementor, and under the ‘Actions After Submit’ section, add a new action and select ‘Webhook’. Paste the webhook URL from Pabbly Connect into the designated field.
  • Update your form settings and publish the changes.
  • Test the form submission to ensure it sends data to Pabbly Connect.
After testing the form submission, return to your Pabbly Connect dashboard. You should see the response from the form submission, confirming that your webhook is working correctly. This integration allows Pabbly Connect to receive data seamlessly for the next steps.
5. Setting Up Actions in Pabbly Connect
With your trigger set up, it’s time to configure the actions in Pabbly Connect. First, select ‘Nish’ as your action application and choose the action event ‘Add User to a Course’. This action will automatically create a user in Nish whenever a new form submission occurs.
Next, you’ll need to connect your Nish account by providing the necessary API key and website URL. After establishing the connection, map the data fields from the webhook response to the required fields in Nish, such as name, email, and course ID.
After setting up the Nish action, add another action step for ‘ConvertKit’. Select ‘Add Subscriber to a Form’ and connect your ConvertKit account. Again, map the necessary fields to ensure the subscriber is created correctly. Once both action steps are configured, you can test the workflow to ensure everything works as intended.
In this tutorial, we demonstrated how to integrate Nish and ConvertKit using Pabbly Connect. By automating user creation and subscriber management, you can save time and streamline your processes. Pabbly Connect simplifies these integrations, enhancing your workflow efficiency.
