Learn how to integrate Mojo with PAB Using Pabbly Connect for seamless automation of email marketing. Follow this detailed tutorial for step-by-step instructions. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities. with Pabbly Connect.
1. Setting Up the Integration with Mojo and PAB
To integrate Mojo with PAB, you first need to set up the automation. The primary application for this integration is P Connect Now. Start by logging into your P Connect Now account, where you will create a workflow that connects Mojo and PAB.
Once logged in, click on the ‘Create Workflow’ button. You will be prompted to name your workflow. For this task, name it something like ‘Create Subscriber in PAB from Mojo Payments’. After naming, select the folder to save the workflow and click on ‘Create’.
2. Configuring the Trigger for Successful Payments
The next step is to configure the trigger for the workflow. The trigger application you will use is Mojo, specifically the version two. Search for Mojo and select it as your trigger application.
Now, set the trigger event to ‘Successful Payment’. This ensures that every time a payment is successfully processed in Mojo, it will trigger the workflow. After selecting the trigger event, you will need to connect Mojo to P Connect using a specific VAB URL. Follow these steps:
- Copy the VAB URL provided by P Connect.
- Log into your Mojo account and navigate to your payment pages.
- In the page settings, enable the webhook option and paste the VAB URL.
After saving the settings in Mojo, you are ready to proceed with the next step in P Connect.
3. Adding Action to Create a Subscriber in PAB
Now that the trigger is set, it’s time to add the action that will create a new subscriber in PAB. For this, search for PAB in the action application section and select it.
Choose the action event ‘Add Subscriber’ to ensure that customer details are added to your email list in PAB. You will need to connect your PAB account to P Connect. To do this, obtain your API token from your PAB account:
- Log into your PAB account and navigate to Integrations.
- Go to Developer API and regenerate your API token.
- Copy the token and paste it back into P Connect to establish the connection.
Once connected, select the list where you want to add the new subscribers and map the customer details from the Mojo payment response.
4. Testing the Integration to Ensure Functionality
With the workflow configured, it’s essential to test the integration to confirm that it works correctly. To do this, create a new successful payment through Mojo. This action will trigger the workflow you set up in P Connect. using Pabbly Connect
After making a payment, return to P Connect and check the workflow status. You should see the response from Mojo indicating that a new payment has been received. This response will include customer details such as name and email, which will be used to create the subscriber in PAB.
Upon receiving the response, P Connect will automatically add the new subscriber to your specified list in PAB, confirming the integration is functioning as intended. You can verify this by checking your PAB subscriber list.
5. Conclusion: Automating Your Email Marketing with Mojo and PAB
In conclusion, integrating Mojo with PAB using P Connect Now allows you to automate the process of adding new subscribers based on successful payments. This setup not only saves time but also enhances customer engagement through timely email communications.
By following the steps outlined in this tutorial, you can streamline your email marketing efforts and ensure that every customer who makes a payment is automatically added to your email list, allowing for targeted campaigns and improved customer relationships.
