Learn how to integrate Mojo with GetResponse using Pabbly Connect. This tutorial covers each step in detail for seamless automation. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start the integration process, access Pabbly Connect by visiting its homepage. Here, you will find options to sign in or sign up for an account. If you are a new user, clicking on ‘Sign Up Free’ allows you to explore the software with 300 free tasks each month.
Once you have logged into your existing account, you will see the dashboard. This is where you can manage your workflows and integrations. To create a new workflow, click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
In the ‘Create Workflow’ dialog box, name your workflow something descriptive, like ‘Create GetResponse Contact on Mojo Sale’. Select a folder for your workflow, such as ‘Contacts’, and then click on the ‘Create’ button to proceed. using Pabbly Connect
- Choose the correct folder for organization.
- Click on ‘Create’ to finalize your new workflow.
After creating the workflow, you will see a trigger and action setup. The trigger will be your Mojo account, and the action will be to create a new contact in GetResponse when a sale is made.
For the trigger, select ‘Instam Mojo’ as your application and choose ‘New Sale’ as the trigger event. This ensures that every time a new sale occurs, Pabbly Connect will capture the details automatically.
You will receive a webhook URL in Pabbly Connect that you need to copy. Next, log into your Instam Mojo account, select the product you are selling, and paste the webhook URL in the respective field under the advanced settings for webhooks.
- Select ‘Instam Mojo’ as the trigger application.
- Choose ‘New Sale’ as the trigger event.
- Paste the webhook URL in your Instam Mojo settings.
After saving the webhook settings in Mojo, you will need to perform a test sale to ensure that the webhook is functioning correctly. This will allow Pabbly Connect to receive a response from the sale.
4. Configuring the Action in Pabbly Connect
Once the trigger is set up, it’s time to configure the action. Select ‘GetResponse’ as your action application and choose ‘Create Contact’ as your action event. This will automate the process of adding a new contact whenever a sale occurs in Mojo.
To connect GetResponse with Pabbly Connect, click on ‘Connect’ and choose ‘Add New Connection’. You will need to enter your GetResponse API key, which you can generate from your GetResponse account settings.
Select ‘GetResponse’ as the action application. Choose ‘Create Contact’ as the action event. Enter your GetResponse API key when prompted.
After entering the API key, you will successfully connect GetResponse with Pabbly Connect. Now, you can map the necessary fields such as name, email, and phone number from the Mojo sale details to the contact fields in GetResponse.
5. Testing the Integration in Pabbly Connect
To test the integration, perform another sale in your Instam Mojo account. Make sure to enter customer details like email and phone number during the checkout process. After completing the sale, check your GetResponse account to see if the new contact has been created successfully.
If everything is set up correctly, you should see the new contact reflecting in your GetResponse account with the details you provided during the sale. This confirms that Pabbly Connect has successfully automated the integration between Mojo and GetResponse.
In summary, you have set up an automated process where new sales in Mojo trigger the creation of contacts in GetResponse, all facilitated by Pabbly Connect. This integration not only saves time but also ensures that your contact list is always up to date.
In this tutorial, we demonstrated how to integrate Mojo with GetResponse using Pabbly Connect. This step-by-step guide ensures that every sale made in Mojo automatically creates a new contact in GetResponse, streamlining your workflow and enhancing your marketing efforts.
