Learn how to integrate Mojo with ConvertKit using Pabbly Connect for automated subscriber management. Follow our detailed tutorial for seamless setup. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To begin integrating Mojo with ConvertKit, first access Pabbly Connect. This platform allows you to automate workflows seamlessly between different applications. You can sign in or sign up at the Pabbly Connect homepage, where new users receive 300 free tasks monthly.
After logging in, you will see the dashboard. Here, you can create a new workflow by clicking the ‘Create Workflow’ button. This step is crucial as it sets the foundation for connecting your applications.
In this section, you will create a workflow that triggers when a payment fails in Mojo. Select the ‘Create Workflow’ option and name it something descriptive, such as ‘Create ConvertKit Subscriber on Failed Mojo Payment.’ This workflow will allow you to automate the process of adding users as subscribers in ConvertKit.
- Click on the ‘Create’ button to finalize the workflow.
- Define the trigger as ‘Instamojo’ and select the event ‘Failed Payment.’
Now, you have successfully set up the initial trigger for your workflow. This allows Pabbly Connect to receive data whenever a payment fails through Mojo.
3. Setting Up the Webhook in Mojo
Next, you need to configure Mojo to send payment failure notifications to Pabbly Connect. Log in to your Mojo account and navigate to the payment page settings. Here, you will paste the webhook URL you copied earlier.
In the settings, look for the option labeled ‘Webhook’ and enter the URL. Ensure you select the information to be sent as ‘Failed Payments.’ This configuration is essential for enabling the communication between Mojo and Pabbly Connect.
4. Testing the Integration
After setting up the webhook, it’s time to test the integration. Make a test payment on your Mojo payment page. Use dummy data to simulate a failed payment scenario. Once the payment fails, Pabbly Connect should capture the webhook response, confirming that the integration is working correctly.
- Enter test user details such as name, email, and phone number.
- Proceed to payment and ensure it fails to trigger the webhook.
- Check Pabbly Connect for the received response.
Upon successful testing, you will see the user details captured in Pabbly Connect, confirming the workflow is functioning as intended.
5. Adding Subscriber to ConvertKit
Now that the integration is tested, you can set up the action to add a subscriber to ConvertKit. In Pabbly Connect, select ConvertKit as the action application and choose ‘Add Subscriber to a Form’ as the action event. This step ensures that when a payment fails, the user gets added to your ConvertKit email list.
Connect your ConvertKit account by entering the API key and secret. After connecting, map the necessary fields from the webhook response to the ConvertKit form fields, such as first name, email, and last name. This mapping is essential for ensuring that the correct data is sent to ConvertKit.
Finally, test this action step to confirm that the subscriber is added successfully. Refresh your ConvertKit account to see the new subscriber listed, ensuring that Pabbly Connect is effectively managing the integration.
In this tutorial, we explored how to integrate Mojo with ConvertKit using Pabbly Connect. By setting up triggers and actions, you can automate the process of adding subscribers seamlessly, enhancing your email marketing efforts. This integration not only saves time but also improves customer engagement by addressing payment failures promptly.
