Learn how to seamlessly integrate MemberPress with ThriveCart using Pabbly Connect. This detailed tutorial covers every step for automating your subscription process. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect for ThriveCart and MemberPress Integration
To integrate MemberPress with ThriveCart, the first step is to set up Pabbly Connect. This platform allows you to automate workflows between different applications. Start by signing up for a free account on Pabbly Connect, which provides free automation tasks every month.
Once signed up, log into your Pabbly Connect dashboard. Here, click on the ‘Create Workflow’ button. Name your workflow appropriately, such as ‘Create MemberPress Subscriber from ThriveCart Purchase,’ and click ‘Create’. This will load the workflow page where you can define triggers and actions for your automation.
2. Setting ThriveCart as the Trigger in Pabbly Connect
In this section, you will set ThriveCart as the trigger application in Pabbly Connect. Click on the trigger window and search for ThriveCart. Select the trigger event as ‘Product Purchase’. This event will start the workflow whenever a purchase is made on ThriveCart.
Next, click on the ‘Connect’ option and select ‘Add New Connection’. You will need to provide the API key or token from your ThriveCart account. To find this, go to your ThriveCart settings, navigate to the API and Webhooks section, and create a new API key. Copy this key and paste it in Pabbly Connect before saving the connection.
  • Select ‘Product Purchase’ as the trigger event.
  • Connect your ThriveCart account using the API key.
  • Save the connection to proceed.
After setting up the trigger, you can test the connection by simulating a purchase on ThriveCart. This will ensure that your Pabbly Connect setup is correctly configured to capture purchase data.
3. Creating a MemberPress Subscriber via Pabbly Connect
Once the trigger is set, the next step is to create a subscriber in MemberPress using the data captured from ThriveCart. In your Pabbly Connect workflow, search for MemberPress in the action section and select the ‘Create Member’ option.
Click on ‘Connect’ and then ‘Add New Connection’ to enter your MemberPress API key and the site URL of your WordPress site. You can find the API key in the MemberPress plugin under the Developer section. Once connected, you will need to map the customer details from the ThriveCart purchase to the MemberPress fields.
  • Map the email address and username from ThriveCart data.
  • Provide a password for the new MemberPress account.
  • Select whether to send a welcome email.
After mapping the necessary fields, click on ‘Save and Send Test Request’ to create a subscriber in MemberPress. You should receive a confirmation response indicating that a new member has been created.
4. Setting Up a Subscription for the New Member
Following the creation of the member, the next step in Pabbly Connect is to set up a subscription for the newly created MemberPress member. Click on the plus icon to add another action and select MemberPress again, this time choosing ‘Create Subscription’ as the action event.
Use the existing connection to MemberPress that you created earlier. In this step, you will need to map the member’s WordPress ID and the subscription details. Make sure to select the membership type and provide the subscription start date in the correct format.
Map the member’s WordPress user ID from the previous step. Select the membership type (e.g., Lifetime). Provide the subscription total amount and status.
Once all details are mapped, click ‘Save and Send Test Request’. A new subscription will be created for the member, and you should see a response confirming the creation of the subscription.
5. Finalizing the Subscription Status in MemberPress
The final step involves ensuring that the subscription status is marked as active in MemberPress. Again, use Pabbly Connect to add an action for MemberPress and select ‘Create Transaction’ as the action event.
In this step, you will need to map the transaction details, including the total amount and the member’s WordPress user ID. This will complete the transaction and activate the subscription. Once all required fields are filled, click ‘Save and Send Test Request’ to finalize the process.
Map the transaction number and total amount from ThriveCart. Ensure the status of the subscription is set to complete. Use the membership ID from the previous subscription step.
After testing the connection, refresh your MemberPress subscribers’ section to confirm that the new subscriber is now active. This automation will now run seamlessly every time a purchase is made through ThriveCart.
This tutorial demonstrated how to automate the integration of MemberPress and ThriveCart using Pabbly Connect. By following these steps, you can streamline your subscription management and save time on manual entries. Automating this process allows you to focus more on your business while ensuring that every purchase is handled efficiently.
