Learn how to integrate Marquiz with ActiveCampaign using Pabbly Connect to automate contact creation from quiz responses. Follow our step-by-step tutorial for seamless integration. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To begin using Pabbly Connect, first, navigate to its homepage. This powerful automation platform allows you to seamlessly connect various applications, including Marquiz and ActiveCampaign.
Once on the homepage, you can either sign in if you’re an existing user or sign up for a free account. Signing up grants you access to 300 tasks per month, enabling you to explore the functionalities of Pabbly Connect.
After logging into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button located at the top right corner of your dashboard.
- Name your workflow as ‘Create ActiveCampaign Contact for Marquiz Response’.
- Select a folder for your workflow, such as ‘Automations’.
- Click on the ‘Create’ button to finalize your workflow setup.
This workflow will serve as the backbone for your automation, connecting Marquiz to ActiveCampaign through Pabbly Connect.
3. Setting Up the Trigger with Marquiz
In this section, you will set up the trigger for your workflow. Select Marquiz as your trigger application and choose the event as ‘New Leads’. This means that whenever a new lead completes a quiz, Pabbly Connect will initiate the workflow.
After selecting the trigger, Pabbly Connect will provide you with a webhook URL. Copy this URL and head over to your Marquiz account. In your Marquiz form settings, navigate to the Integrations section and select ‘Webhooks’ to add the copied URL. This links your Marquiz form to Pabbly Connect.
4. Configuring the Action with ActiveCampaign
Now it’s time to set up the action step in your workflow. Choose ActiveCampaign as your action application and select the event ‘Create a Contact’. This ensures that each new lead from Marquiz is automatically added as a contact in ActiveCampaign.
To connect ActiveCampaign with Pabbly Connect, you will need to enter your API key and URL. Access these details from your ActiveCampaign account under the Developer settings. Make sure to follow the instructions carefully, especially regarding the URL format.
- Map the fields for email, first name, last name, and phone number from the Marquiz response.
- Click on ‘Save and Send Test Request’ to verify the connection.
Once the test is successful, your integration is complete, and Pabbly Connect will handle future lead submissions automatically.
5. Testing the Integration
To ensure everything is functioning correctly, perform a test submission on your Marquiz form. Enter dummy data and submit the form. This action will trigger the workflow in Pabbly Connect and create a new contact in your ActiveCampaign account.
After submitting the form, check your ActiveCampaign account to see if the new contact appears with the correct details. This step confirms that the integration works as intended, allowing you to engage with leads effectively.
In this tutorial, we demonstrated how to integrate Marquiz with ActiveCampaign using Pabbly Connect. This automation streamlines the process of capturing leads and creating contacts, enhancing your marketing efforts. By following these steps, you can efficiently manage your leads and improve engagement.
