Learn how to integrate Marquiz with ActiveCampaign using Pabbly Connect for seamless automation. This tutorial covers every step in detail. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To start integrating Marquiz with ActiveCampaign, you first need to access Pabbly Connect. Visit the Pabbly website and log in using your credentials. If you are a new user, you can sign up for a free account, which allows you to explore the features of Pabbly Connect.
Once logged in, you will land on the Pabbly Connect dashboard. Here, you can create workflows that automate tasks between different applications. This is crucial for setting up the connection between Marquiz and ActiveCampaign, allowing seamless data transfer whenever a new lead is generated.
After accessing Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard. You will be prompted to name your workflow; for this integration, name it ‘Create ActiveCampaign Contact for Marquiz Response’.
- Select a folder for better organization.
- You can create new folders as needed.
Once the workflow is named, you will see options for setting up a trigger and action. This is where you will specify that the trigger is a new lead from Marquiz, and the action will be to create a new contact in ActiveCampaign.
3. Setting Up the Trigger with Marquiz
To set up the trigger in Pabbly Connect, select Marquiz as your trigger application. Choose the event ‘New Lead’ so that every time a new lead is generated through the Marquiz form, it triggers the workflow. You will receive a webhook URL that you will need to connect back to your Marquiz account.
Log in to your Marquiz account and navigate to the specific quiz you want to integrate. Click on the ‘Edit’ button and select the ‘Integrations’ tab. Here, choose ‘Webhooks’ and paste the webhook URL provided by Pabbly Connect. Make sure to save your changes and publish the form to activate the integration.
4. Configuring the Action with ActiveCampaign
Now that you have set your trigger in Pabbly Connect, it’s time to configure the action with ActiveCampaign. Select ActiveCampaign as your action application and choose ‘Create a Contact’ as the action event. This means that whenever a new lead is captured through Marquiz, a new contact will automatically be created in ActiveCampaign.
To connect your ActiveCampaign account, you will need to enter your API Key and URL. You can find these details under the ‘Developer’ section in your ActiveCampaign account settings. Make sure to follow the instructions carefully, especially regarding the URL format. After entering the details, click on ‘Save’ to establish the connection.
With everything set up in Pabbly Connect, it’s time to test your integration. Go back to your Marquiz form and submit a test response to ensure that the data flows correctly into ActiveCampaign. Fill in the necessary fields with dummy data and submit the form.
- Enter a test first name and last name.
- Provide a valid email address.
- Submit the form to trigger the workflow.
After submitting, check your ActiveCampaign account to confirm that the new contact has been created successfully. This step validates that your integration between Marquiz and ActiveCampaign through Pabbly Connect is functioning as intended.
In this tutorial, we explored how to integrate Marquiz with ActiveCampaign using Pabbly Connect. This seamless integration allows you to automate the creation of contacts based on new leads generated from your quizzes, enhancing your engagement with potential clients.
By following these steps, you can efficiently streamline your workflow and improve your marketing efforts.
