Learn how to automate the creation of subscribers from MailerLite to Flowdesk using Pabbly Connect. Follow this detailed tutorial for seamless integration. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To begin integrating MailerLite with Flowdesk using Pabbly Connect, first, access the Pabbly Connect dashboard. You can do this by signing in or signing up if you are a new user. Once logged in, you will receive 100 free tasks to start your automation journey.
After signing in, locate the ‘Create Workflow’ button on the right side of the dashboard. Click on it to open a dialog box where you can name your workflow, such as ‘Create Flowdesk Subscriber from MailerLite Classic’. This naming reflects your integration objective.
2. Setting Up the Trigger with MailerLite Classic
In this step, you will set up the trigger that initiates the integration. Choose MailerLite Classic as your trigger application and select the event ‘Subscriber Created’. This event signifies that a new subscriber has been added to MailerLite.
To connect Pabbly Connect with your MailerLite account, click on ‘Connect’ and then select ‘Add New Connection’. You will need to provide an API key from MailerLite. To obtain this key, log in to your MailerLite account, navigate to the API section, and copy the key. Paste it back into Pabbly Connect and click on ‘Save’.
  • Select MailerLite Classic as the trigger application.
  • Choose ‘Subscriber Created’ as the trigger event.
  • Connect to MailerLite by entering the API key.
After saving, click on ‘Save and Send Test Request’ to check if the connection works. This will help you capture a test response from MailerLite, ensuring everything is set correctly.
3. Creating a Subscriber in Flowdesk
Once the trigger is set up, the next step is to create a subscriber in Flowdesk. Add Flowdesk as your action application and select the action event ‘Create or Update Subscriber’. This action will take the subscriber’s information from MailerLite and create a new entry in Flowdesk.
To connect Pabbly Connect with Flowdesk, click on ‘Connect’ and select ‘Add New Connection’. You will be prompted to authorize access to your Flowdesk account. After granting permission, you can proceed to fill in the subscriber details.
  • Select ‘Create or Update Subscriber’ in Flowdesk.
  • Map the email, first name, last name, and other details from MailerLite.
  • Click ‘Save and Send Test Request’ to create the subscriber.
This mapping process ensures that the data from MailerLite is correctly transferred to Flowdesk, making sure that the subscriber’s information is accurate and complete.
4. Adding the Subscriber to a Segment in Flowdesk
The final step involves adding the created subscriber to a specific segment in Flowdesk. You can do this by adding another action step in Pabbly Connect. Choose Flowdesk again and select the action event ‘Add Existing Subscriber to a Segment’.
In this step, you will need to provide the subscriber’s email and the segment name where you want to add them. Ensure you have already created the segment in Flowdesk beforehand. After entering these details, click on ‘Save and Send Test Request’ to finalize the integration.
Select ‘Add Existing Subscriber to a Segment’ in Flowdesk. Enter the subscriber’s email and the segment name. Click ‘Save and Send Test Request’ to complete the process.
Once this is done, check Flowdesk to ensure that the subscriber has been successfully added to the designated segment. This step confirms that the integration works flawlessly.
In this tutorial, we demonstrated how to integrate MailerLite with Flowdesk using Pabbly Connect. By following these steps, you can automate the subscriber creation process and enhance your email marketing efforts effectively. This integration allows for seamless data flow between applications, making your workflow efficient.
