Learn how to integrate MailerLite and Monday.com using Pabbly Connect to automate subscriber creation based on column value changes. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start integrating MailerLite and Monday.com, first, access Pabbly Connect. You can sign in if you’re an existing user or create a new account, which takes just a few minutes.
Upon signing up, you will receive 100 free tasks to explore the platform. After logging in, you will see the dashboard where you can create a new workflow.
In Pabbly Connect, click on the ‘Create Workflow’ button on the right side of the dashboard. Name your workflow according to your objective, such as ‘Create MailerLite Subscriber from Monday.com’ and click on ‘Create’.
- Click on ‘Create Workflow’
- Name your workflow
- Select the trigger and action applications
Next, you will choose your trigger application, which is Monday.com. The trigger event will be ‘Specific Column Value Changed in Board’. This will initiate the workflow whenever a specific column value changes in your Monday.com board.
3. Setting Up Monday.com Integration with Pabbly Connect
Once the trigger is set, Pabbly Connect will generate a webhook URL. This URL acts as a bridge between Monday.com and Pabbly Connect, allowing data to flow seamlessly. Copy this webhook URL.
Navigate to your Monday.com dashboard, select the board you are working on, and click on the ‘Integrate’ option. Choose ‘Add New Integration’ and select ‘Webhooks’. Paste the copied webhook URL into the designated field and connect.
4. Testing the Integration in Pabbly Connect
After setting up the integration, you need to perform a test submission. Change the status of a lead in Monday.com to ‘Subscribed’. Go back to Pabbly Connect to verify if the webhook received the correct data.
- Change lead status to ‘Subscribed’ in Monday.com
- Check for the response in Pabbly Connect
- Ensure the correct data is displayed
Once the test is successful, you can proceed to set up a filter in Pabbly Connect to ensure the workflow continues only when the status is ‘Subscribed’.
5. Finalizing the Integration with MailerLite
Next, select MailerLite as your action application in Pabbly Connect. The action event will be to create or update a subscriber. Connect your MailerLite account using the API token obtained from your MailerLite account settings.
Map the necessary fields, including email, first name, and last name from the previous steps. After mapping, click on ‘Save and Send Test Request’ to finalize the integration.
Once successful, check your MailerLite account to confirm that the subscriber has been added. This completes the integration process, demonstrating how Pabbly Connect effectively automates the workflow between Monday.com and MailerLite.
This tutorial has shown how to effectively use Pabbly Connect to automate the process of adding subscribers in MailerLite when a lead’s status changes in Monday.com. By following these steps, you can streamline your workflow and enhance your productivity.
