Learn how to automate notifications for new LinkedIn leads to your Discord channel using Pabbly Connect. Step-by-step guide included. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin the integration process, you will first need to access Pabbly Connect. Start by navigating to the Pabbly Connect homepage. Here, you will find options to sign in or sign up. If you are a new user, click on ‘Sign Up Free’ to create an account and receive 100 free tasks every month.
Once you are signed in, you will be directed to the dashboard. This is where you can create a workflow to connect your LinkedIn leads with your Discord channel. Click on the ‘Create Workflow’ button at the top right corner to initiate the setup.
In the workflow creation dialogue, name your workflow, such as ‘Send Discord Channel Messages for New LinkedIn Leads’. You can also select a folder for better organization. After naming your workflow, click on the ‘Create’ button to proceed.
  • Choose the trigger application as LinkedIn Lead Gen Forms.
  • Select the trigger event as New Lead Form Response.
  • Connect your LinkedIn Lead Gen Forms account to Pabbly Connect.
This setup will ensure that whenever a new lead is captured through your LinkedIn form, Pabbly Connect will trigger the workflow to send a message to your Discord channel.
After creating the workflow, you need to set up the trigger. Select LinkedIn Lead Gen Forms as your trigger application. This integration allows you to receive new leads directly from your LinkedIn ads, simplifying the lead collection process.
To connect your LinkedIn account, click on ‘Connect’, then select ‘Add New Connection’. You will be prompted to log in to your LinkedIn account. Once connected, select the account and the lead form you want to use. Generate a test lead to ensure everything is working correctly.
  • Make sure to select the correct lead form for your campaign.
  • Click ‘Save and Send Test Request’ to check if the trigger is set up correctly.
Once the test lead is generated, you can confirm that Pabbly Connect has captured the lead details successfully, allowing you to move on to the next step.
4. Sending a Message to Discord Channel
With your trigger set, it’s time to configure the action. Select Discord as your action application and choose ‘Send Channel Message’ as your action event. This action will notify your team on Discord whenever a new lead comes in.
To connect Discord, click on ‘Connect’ and you will need to provide your Discord Webhook URL. To get this, go to your Discord channel settings, select Integrations, and create a new webhook. Copy the webhook URL and paste it into Pabbly Connect.
Enter a message template that includes lead details such as first name, last name, email, and phone number. Use data mapping to dynamically insert lead information into the message.
Once you have configured the message, click ‘Save and Send Test Request’ to send a test message to your Discord channel. This will confirm that your setup is complete and functioning as expected.
5. Conclusion
In this tutorial, we explored how to automate notifications for new LinkedIn leads to your Discord channel using Pabbly Connect. By setting up a trigger with LinkedIn Lead Gen Forms and an action with Discord, you can ensure your team stays informed about new leads in real-time. This integration streamlines communication and enhances your lead management process.
Using Pabbly Connect not only saves time but also improves efficiency, allowing teams to respond promptly to potential clients. Start automating your workflows today for a more organized approach to lead management!
