Learn how to integrate LinkedIn Lead Ads with Go High Level using Pabbly Connect to automate the creation of new contacts from leads. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start the integration process, we need to access Pabbly Connect. This platform will facilitate the connection between LinkedIn Lead Ads and Go High Level. Open your browser and navigate to the Pabbly Connect website.
If you do not have an account, click on the ‘Sign up for free’ button. This process takes only a couple of minutes, and you will receive 100 free tasks each month. If you already have an account, sign in to access your dashboard.
After logging into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button. A window will pop up, prompting you to name your workflow. Name it something descriptive, like ‘Create Go High Level Contact from LinkedIn Lead Ads’.
- Select the appropriate folder for your workflow.
- Click on ‘Create’ to finalize the workflow setup.
This action will bring you to the workflow window, where you will set up the trigger and action for your integration.
In this section of Pabbly Connect, you will set up the trigger application. Select ‘LinkedIn Lead Generation Forms’ as your trigger application. Then, specify the trigger event as ‘New Lead Generation Form Response’. This event will activate when a new lead is generated.
Next, you need to connect your LinkedIn account with Pabbly Connect. Click on ‘Connect’, and then add a new connection. Once you log in to your LinkedIn account, your connection will be established successfully.
4. Mapping Lead Details to Go High Level
With the trigger set up, the next step involves mapping the lead details to Go High Level. For this, select ‘Lead Connector V2’ as your action application in Pabbly Connect. Choose ‘Create Contact’ as your action event. This will allow you to create a new contact in Go High Level whenever a new lead is generated.
- Connect Lead Connector V2 with your Go High Level account.
- Map the details from the lead form, such as first name, last name, email, and phone number.
This mapping process ensures that every new lead captured from LinkedIn is automatically added as a contact in Go High Level, streamlining your lead management process.
After mapping the lead details, it is crucial to test the integration. Click on the ‘Save and Send Test Request’ button in Pabbly Connect. This action will send a test request to ensure that the integration works seamlessly.
Once the test is successful, you will receive a positive response indicating that a new contact has been created in Go High Level. You can verify this by checking the contacts section in your Go High Level account, where you should see the newly created contact with the details you specified.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate LinkedIn Lead Ads with Go High Level. By following these steps, you can automate the creation of new contacts from leads, enhancing your lead management process. This integration saves time and improves efficiency for your marketing campaigns.
