Learn how to integrate JotForm with SendPulse using Pabbly Connect. This detailed tutorial covers every step of the automation process for seamless subscriber management. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start integrating JotForm with SendPulse, first, you need to access Pabbly Connect. Open your browser and search for Pabbly Connect to reach its landing page. Here, you’ll find options to sign in or sign up for free if you are a new user.
For existing users, click on the sign-in button. Once logged in, you will see the dashboard with various Pabbly applications. Click on the Pabbly Connect icon to begin setting up your workflow for integrating JotForm and SendPulse.
In this step, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button, and a prompt will ask for the workflow name. Name your workflow something descriptive, like ‘JotForm to SendPulse Integration’. Choose a folder to save it in, then click ‘Create’.
  • Select a folder for organization.
  • Click ‘Create’ to open the workflow window.
Now, you will be in the workflow window, where you can set up triggers and actions. For this integration, select JotForm as the trigger application. This is crucial because it will initiate the workflow when a new form response is submitted.
3. Setting Up the JotForm Trigger
In Pabbly Connect, you need to specify the trigger event. Choose ‘New Response’ from the list of trigger events. This step is essential as it will activate the workflow whenever a new submission is made in your JotForm account.
After selecting the trigger event, Pabbly Connect provides a webhook URL. This URL is used to connect your JotForm account with the workflow. Copy this URL, as you will need it in the next steps to complete the integration.
4. Integrating JotForm with Pabbly Connect
Now, navigate to your JotForm account to integrate it with Pabbly Connect. Open the form you want to use for this integration and go to the settings. Under the integrations section, find and select ‘Webhooks’.
  • Paste the copied webhook URL into the Webhook settings.
  • Click on ‘Complete Integration’ to finalize the connection.
  • Check for a confirmation tick mark indicating successful integration.
Once the integration is complete, you can publish the form. This will allow you to test the form submission and ensure that data is being captured correctly in Pabbly Connect.
5. Adding Subscriber in SendPulse
After confirming the JotForm integration, the next step in Pabbly Connect is to set up the action for SendPulse. Choose SendPulse as the action application and select the ‘Add Subscriber’ action event. This allows Pabbly Connect to add new subscribers automatically.
To connect your SendPulse account, you will need to provide your API ID and secret. Log into your SendPulse account, navigate to account settings, and retrieve your API credentials. Paste these credentials into Pabbly Connect to establish the connection.
In this tutorial, we demonstrated how to integrate JotForm with SendPulse using Pabbly Connect. By following the steps outlined, you can automate the process of adding new subscribers seamlessly. This integration enhances your workflow and ensures efficient subscriber management.
