Learn how to integrate Instamojo with Go High Level using Pabbly Connect step-by-step, automating customer contact creation effortlessly. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To start integrating Instamojo with Go High Level, you first need to access Pabbly Connect. This platform is essential for automating workflows between different applications. You can sign up for a free account to explore its features and capabilities.
Once you are on the Pabbly Connect homepage, you will see options to either sign in or sign up. If you are a new user, click on ‘Sign Up Free’ to create an account. Existing users should click on ‘Sign In’ to access their dashboard.
After logging into Pabbly Connect, the next step is to create a workflow. This workflow will facilitate the integration of Instamojo with Go High Level. To do this, click on the ‘Create Workflow’ button located at the top right corner of the dashboard.
In the dialog box that appears, you need to name your workflow. For instance, you can name it ‘Create or Update Go High Level Contact on Instamojo Payment.’ Next, select a folder to save your workflow. You can choose an existing folder or create a new one for better organization.
- Click on ‘Create’ to finalize your workflow setup.
- Ensure you understand the trigger and action principles of automation.
With the workflow created, you are now ready to set up the trigger for the automation process.
3. Setting Up the Trigger for Instamojo
In this section, you will configure the trigger for your workflow using Pabbly Connect. Select Instamojo as your trigger application. The trigger event will be set to ‘New Sale,’ which means that every time a new sale is made through Instamojo, the workflow will activate.
After selecting the trigger event, Pabbly Connect will provide you with a webhook URL. This URL is crucial as it will connect your Instamojo account to Pabbly Connect. Copy this URL to use it in the next steps.
- Log into your Instamojo account.
- Navigate to the payment page you want to edit.
- Paste the webhook URL in the relevant settings under ‘Webhook’.
Once the webhook URL is set up, you can save the changes and proceed to test the integration.
4. Testing the Integration with a Test Payment
To ensure that the integration works seamlessly, you will need to perform a test payment using Instamojo. This step is crucial to verify that Pabbly Connect receives the webhook response correctly. Go to your payment page and fill in the required details to make a test payment.
After entering the payment information, select your payment method and complete the transaction. Once the payment is successful, return to your Pabbly Connect dashboard to check if the webhook response was received. You should see details such as the payment status, buyer’s name, and email address.
Confirming the successful webhook response indicates that the trigger is functioning correctly, and you can now proceed to set up the action step in your workflow.
5. Setting Up the Action to Create Contacts in Go High Level
In this final step, you will configure the action that will take place once a new payment is received through Instamojo. In Pabbly Connect, select the action application as ‘Lead Connector V2’ to connect with Go High Level.
Choose the action event as ‘Create or Update a Contact.’ This action ensures that every new customer who makes a payment will automatically be added as a contact in your Go High Level account. To connect your Go High Level account, click on ‘Connect with Lead Connector V2’ and select your specific sub-account.
Map the relevant fields from the webhook response to the contact fields in Go High Level, such as first name, last name, email, and phone number. Once you have mapped all necessary fields, click on ‘Save and Send Test Request’ to finalize the setup. This will create a new contact based on the payment details received.
In this tutorial, we explored how to integrate Instamojo with Go High Level using Pabbly Connect. By automating the process of creating or updating customer contacts, you can enhance your business efficiency and maintain accurate customer records effortlessly.
