Learn how to integrate Instamojo with Brevo using Pabbly Connect for automatic contact updates. Follow this detailed tutorial for seamless automation! Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Introduction to Pabbly Connect for Instamojo and Brevo Integration
In this tutorial, we will explore how to use Pabbly Connect to add or update Brevo contacts whenever a sale is made on Instamojo. By automating this process, you can keep your contact list up to date without manual intervention.
Using Pabbly Connect, you can seamlessly integrate various applications, including Instamojo and Brevo. This integration ensures that whenever a new sale occurs, the corresponding contact information is automatically added or updated in your Brevo account.
2. Setting Up Pabbly Connect for Automation
To begin, access Pabbly Connect by visiting the Pabbly Connect website. If you’re a new user, you can sign up for free and explore the features available. Existing users can simply log in to their accounts.
  • Go to the dashboard and select ‘Create Workflow’.
  • Name your workflow, for instance, ‘Add or Update Brevo Contact on Instamojo Sale’.
  • Click on ‘Create’ to open the workflow window.
Once the workflow window is open, you will set up a trigger and an action. The trigger will be from Instamojo, which initiates the workflow when a new sale is made, while the action will be to create or update a contact in Brevo using Pabbly Connect.
3. Configuring the Instamojo Trigger in Pabbly Connect
To set the trigger, select Instamojo as the application in Pabbly Connect. Choose the trigger event as ‘New Sale’. This event will activate the workflow whenever a sale occurs on your Instamojo account.
After selecting the trigger, Pabbly Connect will provide a webhook URL. You need to copy this URL and paste it into your Instamojo account under the settings for the product you want to track.
  • Go to your Instamojo account and select the product.
  • Navigate to ‘Advanced Settings’ and find the ‘Webhook’ section.
  • Paste the copied webhook URL and select ‘Successful Payments’ for the information to be sent.
After saving these settings, you will need to perform a test submission to ensure that Pabbly Connect captures the response correctly.
4. Testing the Webhook Response in Pabbly Connect
To test the webhook response, go back to your Instamojo account and make a test purchase. Fill in the necessary details such as name, email, and phone number, then proceed to payment.
Once the payment is successful, Pabbly Connect will capture the response from the sale. You can verify this by checking your Pabbly Connect workflow, where the captured details will appear.
Ensure that the payment status is marked as successful. Check the details of the buyer to confirm that they match what was entered during the purchase.
With a successful test submission, you can now proceed to set up the action step in Pabbly Connect.
5. Setting Up Brevo Action in Pabbly Connect
For the action application, select Brevo in Pabbly Connect and choose the action event ‘Create or Update a Contact’. This step allows you to add or update the contact information in Brevo based on the data received from Instamojo.
To connect your Brevo account, you will need to provide your API key and domain. Retrieve your API key from your Brevo account settings and enter it in Pabbly Connect. Make sure to map the email and other details from the previous response to create a new contact.
Map the email, first name, and last name from the data captured in the trigger step. Ensure that you enable the update option to allow for contact updates.
After configuring these details, click on ‘Save and Send Request’ to finalize the workflow. You will receive a confirmation that the contact has been successfully created or updated in your Brevo account.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the process of adding or updating Brevo contacts whenever a sale is made on Instamojo. This integration not only saves time but also ensures that your contact list remains current and organized.
By following these steps, you can streamline your marketing efforts and improve customer engagement through efficient automation.
