Learn how to integrate Insta Mojo with Thinkific using Pabbly Connect for seamless automation of user enrollment. Follow this detailed tutorial for easy setup. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start using Pabbly Connect, visit the Pabbly Connect dashboard. If you’re a new user, sign up quickly to access 100 free tasks. Existing users can simply log in to their accounts.
Once logged in, you’ll see the dashboard where you can create your workflow. Click on the ‘Create Workflow’ button on the right side. Here, you can name your workflow, such as ‘Insta Mojo to Thinkific Enrollment’. This is the first step in automating the integration process.
2. Setting Up the Trigger with Insta Mojo
In this section, we will set up the trigger using Pabbly Connect. The trigger application will be Insta Mojo, and the event will be a new sale. This means every time a payment is made, the workflow will run automatically.
  • Select Insta Mojo as the trigger application.
  • Choose the trigger event as ‘New Sale’.
  • Copy the webhook URL generated by Pabbly Connect.
After copying the webhook URL, you need to log in to your Insta Mojo account and navigate to the product settings. Paste the webhook URL into the advanced settings of the product you wish to integrate, such as ‘PHP for Beginners’. Save the changes to update the webhook.
3. Testing the Integration with a Payment
Now that you have set up the trigger, it’s time to test the integration using Pabbly Connect. Make a test payment on your Insta Mojo payment page to see if the webhook captures the response correctly.
  • Fill in customer details like first name, last name, and email.
  • Click on ‘Review and Make Payment’.
  • Ensure the payment is successfully processed.
After processing the payment, return to Pabbly Connect to check if the webhook response has been captured. You should see details such as payment status and customer information, confirming the integration is working correctly.
4. Enrolling the User in Thinkific
With the payment confirmed, the next step is to enroll the user in Thinkific. This is where Pabbly Connect plays a crucial role in automating this process. Set up Thinkific as your action application in the workflow.
Select Thinkific as the action application. Choose the action event as ‘Enroll User’. Map the user details from the webhook response to the enrollment fields.
After mapping the necessary fields, click on ‘Save and Send Test Request’ to enroll the user. If successful, the user will be enrolled in the specified course in Thinkific, confirming that the integration through Pabbly Connect is complete.
5. Handling Existing Users with Pabbly Connect
In case the user already exists in Thinkific, Pabbly Connect allows you to manage this smoothly. You will use a router feature to direct the workflow based on whether the user exists or not.
Set up a router step in your workflow. Create two routes: one for existing users and another for new users. Map the user ID from the webhook to check for existence.
If the user exists, directly enroll them in the course. If they don’t, create a new user in Thinkific before enrollment. This flexibility provided by Pabbly Connect ensures that every user is handled appropriately during the payment process.
This tutorial has guided you through integrating Insta Mojo with Thinkific using Pabbly Connect. By automating user enrollment after a successful payment, you can streamline your course management effectively. With Pabbly Connect, you can enhance your workflows and improve your efficiency.
