Learn how to automate WhatsApp messaging for inquiries from India M using AI Sensei and P Connect with this detailed tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background. with Pabbly Connect.
1. Setting Up Integration Between India M and AI Sensei
Integrating India M with AI Sensei is essential for automating WhatsApp messages for inquiries. This integration allows businesses to respond quickly to potential customers, enhancing customer engagement. By using P Connect, we can seamlessly connect these platforms without any coding skills.
To get started, navigate to the P Connect website and sign in or sign up for a free account. Once logged in, click on the ‘Create Workflow’ button to initiate the integration process. Here’s a quick overview of the steps:
  • Sign in to your P Connect account.
  • Click on ‘Create Workflow’.
  • Name your workflow for easy identification.
After naming your workflow, you’ll be prompted to set up your trigger and action. This is where you define how the integration will work. The trigger will be set to receive new inquiries from India M, which will then prompt an automated response via WhatsApp.
2. Defining the Trigger for New Leads from India M
The next step is defining the trigger for your workflow. The trigger is crucial as it determines when the automation will be activated. In this case, we will set India M as the trigger application. This means every time there’s a new lead, the automation will kick in. using Pabbly Connect
To set up the trigger, follow these steps:
  • Select India M as the trigger application.
  • Choose the event type as ‘New Leads’.
  • Copy the webhook URL provided by P Connect.
Once you have the webhook URL, it needs to be integrated back into your India M account. This will ensure that every inquiry received is sent to P Connect for processing. This step is critical for establishing a connection between India M and P Connect.
3. Connecting India M with P Connect Using Webhook
Connecting India M with P Connect allows for the automatic transfer of inquiry details. This connection is established through the webhook URL that you copied earlier. By setting this up, every new inquiry on India M will trigger an automated WhatsApp message. using Pabbly Connect
To connect these applications, follow these detailed steps:
Log into your India M account and navigate to the Lead Manager. Select ‘Import/Export Leads’ and then ‘Push API’. Paste the copied webhook URL in the appropriate field.
After pasting the URL, confirm the setup by generating an OTP. This step secures the integration and allows you to receive inquiry details directly in P Connect.
4. Sending WhatsApp Messages Using AI Sensei
Once the integration is complete, the next step is to set up the action that will send WhatsApp messages using AI Sensei. This is where you define what happens when a new inquiry is received from India M. using Pabbly Connect
To configure the WhatsApp messaging action, follow these steps:
Select AI Sensei as the action application. Choose ‘Send Template Message’ as the action event. Map the mobile number of the inquiry sender.
Make sure to create a message template in AI Sensei that will be used for the WhatsApp messages. This template should include personalized elements to enhance engagement with potential customers.
5. Testing the Integration and Finalizing the Setup
The final step is to test the integration to ensure everything works smoothly. Testing allows you to verify that inquiries from India M are being sent correctly to WhatsApp via AI Sensei. using Pabbly Connect
To test the integration, follow these steps:
Create a test inquiry in India M. Check if the inquiry details are received in P Connect. Verify that the WhatsApp message is sent to the inquiry sender.
Once you confirm that the messages are being sent successfully, your integration is complete. This automation will significantly enhance your response time and customer engagement for your industrial supplies and machinery business.
Integrating India M with AI Sensei using P Connect allows businesses to automate responses to inquiries effectively. This setup enhances customer engagement and ensures timely communication, ultimately driving sales and improving customer satisfaction.
