Learn how to automate the process of adding Google Ads leads as subscribers in Kit using Pabbly Connect. Step-by-step tutorial with detailed instructions. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start integrating Google Ads with Kit, you’ll first need to access Pabbly Connect. This platform allows you to automate processes between different applications seamlessly. Simply visit the Pabbly Connect website and log in or sign up for a free account.
After logging in, you’ll see the dashboard where you can create workflows. This is where the magic happens, as you can connect your Google Ads leads directly to your Kit account, ensuring no lead is missed. The first step is to create a new workflow.
In this section, we will create a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located on the top right corner of your dashboard. Name your workflow something descriptive, like ‘Create Kit Subscriber from Google Ads Lead’.
- Click on the ‘Create’ button to finalize your workflow.
- You will see the options for setting up a trigger and an action.
- Select Google Ads as your trigger application.
Once you have created your workflow, you will need to set up the trigger. This is essential because it determines what action will initiate the process of adding new leads to your Kit account. The trigger you will select is ‘New Lead Form Entry’ from Google Ads.
3. Setting Up Google Ads Trigger in Pabbly Connect
Now that you have created your workflow, it’s time to set up the Google Ads trigger in Pabbly Connect. This step ensures that every time a new lead fills out a form in Google Ads, it will trigger the workflow. Select ‘New Lead Form Entry’ as your trigger event.
After selecting the trigger event, you will be provided with a webhook URL. This URL is crucial as it connects your Google Ads account with Pabbly Connect. Copy this URL and navigate to your Google Ads account to set up the lead form.
- Create a new lead form in Google Ads and paste the webhook URL into the lead delivery options.
- Test the connection by sending test data to ensure everything is functioning correctly.
This setup allows Pabbly Connect to capture any new leads generated from your Google Ads campaigns, making the process seamless and efficient.
4. Adding Subscribers in Kit Using Pabbly Connect
With the Google Ads trigger set up, the next step is to configure the action in Pabbly Connect. Select Kit as your action application and choose ‘Add Subscriber to a Form’ as the action event. This step is crucial as it allows the data collected from Google Ads to be sent directly to your Kit account.
To establish this connection, you will need to enter your API key and API secret from your Kit account into Pabbly Connect. Once connected, select the form you want to use for adding subscribers. This ensures that the leads captured from your Google Ads will be organized correctly within Kit.
Map the fields such as first name, last name, email, and phone number from the Google Ads lead data. After mapping the fields, click on ‘Save and Send Test Request’ to finalize the action.
This process allows you to maintain an organized list of subscribers who have shown interest through your Google Ads campaigns, enhancing your marketing efforts significantly.
After completing the setup in Pabbly Connect, it’s essential to test the integration to ensure everything is functioning as expected. Check your Kit account to see if the subscriber has been added successfully. The status should be set to inactive until the subscription is confirmed.
Once you receive the confirmation email, approve the subscription to change the status to active. This final step ensures that you can start engaging with your new subscribers effectively. The entire process from Google Ads to Kit is now automated, saving you time and effort.
With Pabbly Connect, you can easily manage leads and streamline your marketing efforts, ensuring no lead goes unnoticed. This integration not only enhances your workflow but also improves your chances of converting leads into loyal customers.
In this tutorial, we explored how to use Pabbly Connect to automate the process of adding Google Ads leads as subscribers in Kit. This integration enhances efficiency and ensures you can follow up with potential customers promptly.
