Learn how to automatically add Google Ads leads as subscribers in Flodesk using Pabbly Connect. Follow our detailed tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Setting Up Pabbly Connect for Google Ads and Flodesk Integration
To add Google Ads leads to Flodesk as subscribers, the first step is to access Pabbly Connect. This powerful integration tool allows you to automate the process effortlessly. Start by navigating to the Pabbly Connect homepage and signing in or creating a new account if you’re a first-time user.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, you can create a new workflow to connect Google Ads with Flodesk. This connection will enable automatic addition of leads as subscribers whenever a new lead is generated via Google Ads, streamlining your marketing efforts.
Next, you need to create a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard. A dialog box will appear where you can name your workflow. For this integration, name it ‘Add Google Ads Leads to Flodesk as Subscriber’ and select a folder for organization, such as ‘Automations’.
  • You will now see the workflow interface where you can set up triggers and actions.
After creating the workflow, you will see two main components: Trigger and Action. The trigger is the event that starts the workflow, and the action is what happens in response. In this case, the trigger will be a new lead from Google Ads, and the action will be adding that lead to Flodesk.
3. Setting Up the Trigger with Google Ads
Now it’s time to set up the trigger in Pabbly Connect. Select Google Ads as your trigger application. This means that whenever a new lead is generated from your Google Ads campaign, it will trigger the workflow. Choose the trigger event as ‘New Lead Form Entry’ to capture the lead information.
Upon selecting the trigger event, you will receive a webhook URL. This URL is crucial as it will connect Google Ads to Pabbly Connect. Copy this webhook URL and proceed to your Google Ads account to set up the lead form.
  • Create a new campaign in Google Ads and navigate to the lead forms section.
  • Paste the copied webhook URL into the lead delivery option in your Google Ads settings.
This setup ensures that every time a new lead submits their information via Google Ads, it will automatically be sent to Pabbly Connect, triggering the next step of adding them as a subscriber in Flodesk.
4. Adding the Subscriber to Flodesk
After setting up the trigger, the next step in Pabbly Connect is to add the lead as a subscriber in Flodesk. In the action step, select Flodesk as your action application. Choose the action event as ‘Create or Update Subscriber’. This will allow you to add new leads to your email list.
To connect Flodesk with Pabbly Connect, click on the ‘Connect with Flodesk’ button. You will be prompted to log into your Flodesk account. Once logged in, grant Pabbly Connect permission to access your Flodesk account. This step is essential for the integration to function correctly.
Map the required fields such as email, first name, and last name from the lead information received from Google Ads. Select whether to send opt-in confirmation emails to subscribers based on your preferences.
After mapping the fields and configuring the settings, click on the ‘Save and Send Test Request’ button. If everything is set up correctly, you should see a successful response indicating that the subscriber has been added to your Flodesk account.
5. Conclusion
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Google Ads leads into Flodesk as subscribers. By automating this process, you can ensure that new leads are promptly added to your email marketing list, allowing for immediate follow-up. This integration not only saves time but also enhances your engagement with potential customers.
With Pabbly Connect, you can easily manage your leads and streamline your marketing efforts, ensuring that no opportunity is missed. Implementing this integration will help grow your business efficiently.
