Learn how to automate the creation of GoHighLevel contacts on new Instamojo sales using Pabbly Connect in this step-by-step tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To create a GoHighLevel contact on a new Instamojo sale, you first need to access Pabbly Connect. This platform allows you to automate tasks without coding skills. Begin by visiting the Pabbly Connect website.
Once on the site, sign in to your account. If you are a new user, you can sign up for free and get 100 tasks monthly. After logging in, navigate to the Pabbly Connect dashboard where you can create your workflow.
In this section, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and name it ‘How to Create GoHighLevel Contact on New Instamojo Sale’. Select the appropriate folder to save this workflow.
  • Click on ‘Create’ to initiate the workflow.
  • You will see two boxes: one for Trigger and one for Action.
For the Trigger application, select Instamojo and choose the event as ‘New Sale’. This sets the stage for your automation, ensuring that whenever a sale occurs, a new contact is created in GoHighLevel.
3. Connecting Instamojo with Pabbly Connect
To connect Instamojo with Pabbly Connect, you will receive a webhook URL. This URL acts as a bridge between the two applications. Copy this URL and head over to your Instamojo account.
In your Instamojo dashboard, click on ‘Products’ and then ‘All Products’. Select the product you want to connect, scroll down to the ‘Advanced’ section, and paste the webhook URL in the designated area. Click on ‘Save’ to finalize the connection.
4. Making a Test Purchase to Trigger Automation
After setting up the webhook in Instamojo, you need to make a test purchase to trigger the automation in Pabbly Connect. Navigate back to your Instamojo product and click on ‘Buy’. Fill in the required details such as name, email, and phone number.
  • Enter dummy details for the shipping address.
  • Complete the payment process.
Once the payment is successful, return to Pabbly Connect to check if the response has been captured. If successful, you will see the data from the sale, confirming the connection between Instamojo and Pabbly Connect.
5. Creating a Contact in GoHighLevel
Now that you have captured the response from Instamojo, the next step is to create a contact in GoHighLevel using Pabbly Connect. For the Action application, select ‘Lead Connector V2’ and choose ‘Create Contact’ as the action event.
If you don’t have an existing connection, click on ‘Add New Connection’ and authenticate your GoHighLevel account. Once connected, you will need to map the data received from Instamojo, such as the first name, last name, email, and phone number, to the respective fields in GoHighLevel.
After mapping the fields, click on ‘Save and Send Test Request’ to create the contact. Verify in your GoHighLevel account that the contact has been successfully created, confirming that the automation works seamlessly.
By following these steps, you can easily automate the creation of GoHighLevel contacts whenever a new sale occurs on Instamojo using Pabbly Connect. This integration enhances your workflow and ensures that you never miss a potential customer.
