Learn how to automate your email marketing by integrating Go High Level with ConvertKit using Pabbly Connect in this detailed tutorial. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect to Start Integration
To begin integrating Go High Level with ConvertKit, you need to access Pabbly Connect. First, open your browser and search for Pabbly Connect. Once on the landing page, you have two options: sign in or sign up for free if you are a new user.
If you choose to sign up, it only takes a couple of minutes. You will receive 100 free tasks each month. If you already have an account, simply sign in and navigate to the Pabbly Connect dashboard where you can create a new workflow.
Once you are in the Pabbly Connect dashboard, the next step is to create a new workflow. Click on the ‘Create Workflow’ button, which will prompt you to name your workflow. For this integration, you might name it ‘Create ConvertKit Subscriber on Go High Level Form Submission’. using Pabbly Connect
- Click on the ‘Create’ button after naming your workflow.
- Select the folder where you want to save your workflow.
- You will see two boxes for Trigger and Action.
In this window, you will set up the trigger for your workflow. The trigger application will be Lead Connector V2, which connects with Go High Level forms. This setup is essential for automatically creating subscribers in ConvertKit when a form is submitted.
To set up the trigger, search for and select Lead Connector V2. You will then need to specify the trigger event, which is ‘Form Submitted’. This event will initiate the workflow when a form is submitted on Go High Level.
Next, you will need to copy the Webhook URL provided by Pabbly Connect. This URL acts as a bridge between Lead Connector V2 and Pabbly Connect. After copying the URL, navigate to your Go High Level account to set up the connection.
- Select the sub-account in Go High Level where you want to create the workflow.
- Go to Automation and create a new workflow.
- Add the trigger as ‘Form Submitted’ and save it.
With this setup, every time a form is submitted in Go High Level, it will trigger the action in Pabbly Connect.
4. Adding the Action Step in Pabbly Connect
After setting up the trigger, it’s time to add the action step. The action application will be ConvertKit, where you will create a new subscriber. Select ‘Add Subscriber to a Sequence’ as the action event.
To connect ConvertKit with Pabbly Connect, you will need to provide your API key and API secret. Log into your ConvertKit account and navigate to Account Settings to retrieve these details. Once you have copied the API key and secret, paste them into Pabbly Connect and save the connection.
Select the sequence ID in ConvertKit where you want to add the subscriber. Map the fields from the Go High Level form submission to the ConvertKit fields. Ensure that all required fields like first name, last name, and email are correctly mapped.
This mapping allows you to automatically add subscribers to your ConvertKit list as new leads come in through your Go High Level forms.
5. Testing the Integration and Finalizing
With the workflow set up, it’s crucial to test the integration. Go back to your Go High Level form and submit a test entry. For example, fill in the name ‘John Doe’ and an email address like ‘[email protected]’.
After submission, return to Pabbly Connect to see if the webhook response has been received. If successful, you should see the details of the form submission. This confirms that the integration is working as intended, and the subscriber is added to ConvertKit.
Repeat the test with another lead, for example, ‘Michael Caris’. Check ConvertKit to ensure that this new subscriber is also added correctly. This process shows how Pabbly Connect automates the addition of subscribers based on form submissions, enhancing your email marketing strategy.
In this tutorial, we explored how to use Pabbly Connect to integrate Go High Level with ConvertKit, automating the process of adding new subscribers. By following these steps, you can streamline your email marketing efforts effectively.
