Learn how to enroll users from FlexiFunnels into Graphy using Pabbly Connect with this detailed tutorial. Automate your course enrollment process effectively! Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Setting Up Pabbly Connect for FlexiFunnels and Graphy Integration
To start the integration process, first, you need to set up Pabbly Connect. This powerful automation platform enables seamless connections between FlexiFunnels and Graphy. Begin by signing up for a free account on Pabbly Connect, which can be done in just a few minutes.
Once you have logged into your Pabbly Connect account, navigate to the dashboard. Here, click on the ‘Create Workflow’ button and name your workflow, for instance, ‘FlexiFunnels to Graphy.’ This name will help you identify the integration easily in the future.
2. Configuring the Trigger for FlexiFunnels Purchases
In this section, you will set up the trigger to capture new purchases made through FlexiFunnels. Select FlexiFunnels as the app in your Pabbly Connect workflow and choose ‘New Purchase’ as the trigger event. This setup allows Pabbly Connect to listen for any new sales made.
- Select FlexiFunnels from the app list.
- Choose ‘New Purchase’ as the trigger event.
Next, go to your FlexiFunnels account, navigate to the products section, and select the product for which you want to set up this automation. Paste the copied webhook URL into the designated field for webhooks and save the changes. This action establishes the connection between FlexiFunnels and Pabbly Connect, enabling the automation to work.
3. Capturing Purchase Details in Pabbly Connect
After saving the webhook URL, the next step is to test the trigger by making a test purchase on your FlexiFunnels sales page. Fill in the required customer details and complete the order. This will send the purchase data to Pabbly Connect, which will capture the details of the transaction.
Once the purchase is completed, return to your Pabbly Connect workflow. You should see the details captured in the trigger step, including customer name, email, transaction ID, and other relevant information. This confirms that the trigger is functioning correctly.
4. Enrolling the Customer in Graphy
Now that you have captured the purchase details, the next action is to enroll the customer as a learner in Graphy. In the action step of your Pabbly Connect workflow, select Graphy as the app and choose ‘Create Learner’ as the action event. This action allows you to add the customer to your Graphy account automatically.
- Connect your Graphy account by entering the API key and merchant ID.
- Map the email, name, and mobile number fields from the captured purchase data.
- Click ‘Save and Send Test Request’ to finalize the enrollment.
After completing these steps, check your Graphy account under the learners section. You should see the newly added learner with the details you mapped from the purchase data. This indicates successful enrollment through Pabbly Connect.
5. Finalizing the Automation Workflow
The last step in this integration is to enroll the learner into a specific course in Graphy. In the action step, again select Graphy and this time choose ‘Enroll Learner to Course’ as the action event. This will allow you to specify which course the learner should be enrolled in.
Map the learner’s email and the course URL, which you can obtain from your Graphy account. After entering this information, click on ‘Save and Send Test Request.’ Once this is done, the learner will be officially enrolled in the specified course.
To verify, check the learners section of your Graphy course to confirm that the new learner appears there. This confirms that the entire automation workflow is functioning correctly, allowing you to automatically enroll customers who purchase through FlexiFunnels into your Graphy courses using Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to automate the enrollment of customers from FlexiFunnels into Graphy. This integration not only saves time but also ensures that your learners are automatically added to your courses, enhancing your educational offerings.
