Learn how to enroll TagMango users on FlexiFunnels purchases using Pabbly Connect. This detailed tutorial covers all steps for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To begin integrating FlexiFunnels and TagMango, you first need to access Pabbly Connect. You can do this by typing the URL Pabbly.com/connect in your browser. Once there, you will see options to sign in or sign up for free.
If you are an existing user, click on ‘Sign In’. New users can click on ‘Sign Up for Free’ and create an account in just a couple of minutes. This will allow you to explore the features of Pabbly Connect with 100 free tasks each month.
After signing into Pabbly Connect, navigate to the dashboard where you can see all your workflows. To create a new workflow, click on the ‘Create Workflow’ button. A dialog box will prompt you to name your workflow.
- Name the workflow: ‘Enroll TagMango User on FlexiFunnels Purchase’
- Select the folder related to learning management.
This will take you to a new screen with trigger and action sections. Remember, the trigger indicates what starts the workflow, while actions are responses to that trigger.
In the trigger section, select ‘FlexiFunnels’ as the trigger application. The specific event you want to capture is ‘New Purchase’. This means every time a new purchase is made in FlexiFunnels, it will trigger the workflow.
To connect FlexiFunnels with Pabbly Connect, you will receive a webhook URL. This URL needs to be inserted into your FlexiFunnels settings. Copy the webhook URL and navigate to your FlexiFunnels account.
- Go to the product section and select the course you want to connect.
- Click on ‘Set Rules’ and choose the event for the webhook.
- Paste the copied webhook URL and save the settings.
Once set, Pabbly Connect will wait for a response from FlexiFunnels. Proceed to test the integration by making a dummy purchase.
4. Configuring TagMango Integration with Pabbly Connect
Now that the trigger is set, it’s time to configure the action application. In the action section, select ‘TagMango’ and choose ‘Create User’ as the action event. To establish this connection, you will need the API key from your TagMango account.
To find your API key, go to your TagMango dashboard, navigate to the automation section, and copy the API key. Return to Pabbly Connect and paste the API key into the designated field.
You will need to map the user details from the FlexiFunnels response. Map the first name, last name, email, and phone number from the previous step. Ensure you also specify the course ID for the user’s enrollment.
After mapping the details, click on ‘Save and Send Test Request’ to verify that the integration works as expected.
Once you have completed setting up the action step, it’s crucial to test the integration. When you click ‘Save and Send Test Request’, Pabbly Connect will attempt to create a new user in TagMango based on the data received from FlexiFunnels.
Check your TagMango account to confirm that the new user has been added successfully with the appropriate details. This indicates that the integration is working correctly, and every new purchase in FlexiFunnels will automatically enroll users in TagMango.
Verify the user’s details in TagMango. Ensure that the enrollment reflects the correct course. Repeat the process to ensure reliability.
Now you have successfully automated the enrollment process using Pabbly Connect, enhancing your workflow efficiency.
In conclusion, using Pabbly Connect to integrate FlexiFunnels and TagMango simplifies the enrollment process. This tutorial has covered the necessary steps to automate user enrollment effectively, ensuring a seamless experience for your students.
