Learn how to seamlessly integrate Elementor with Zenlo using Pabbly Connect. Follow this step-by-step guide to automate user enrollment with ease. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Accessing Pabbly Connect for Elementor Integration
To start using Pabbly Connect, you’ll first need to access the platform. Simply sign in if you’re an existing user, or create a new account in just a couple of minutes. Upon account creation, you will receive 100 free tasks to test your automations.
Once logged in, you will be directed to the Pabbly Connect dashboard. On the right-hand side, click on the ‘Create Workflow’ button. Here, you can name your workflow according to your objective, such as ‘Enroll User in Zenlo Course for Elementor Form Submission.’ After naming your workflow, select a folder and click ‘Create’ to proceed.
2. Setting Up Elementor as Trigger in Pabbly Connect
In this step, we will set Elementor as the trigger application in Pabbly Connect. The trigger event will be a new form submission. Click on the trigger, select Elementor, and then choose the event labeled ‘New Form Submission’. This event will initiate the workflow every time a new form is submitted.
- Select Elementor as the trigger application.
- Copy the generated webhook URL to connect Elementor with Pabbly Connect.
After copying the webhook URL, navigate to your Elementor form within WordPress. In the form settings, locate the ‘Actions After Submit’ section, click the plus icon, and select ‘Webhook’. Paste the copied URL into the webhook field and save your changes. This setup will allow Pabbly Connect to receive data from Elementor.
3. Testing the Webhook Response in Pabbly Connect
Once the webhook is configured, it’s crucial to test the connection between Elementor and Pabbly Connect. To do this, fill out the Elementor form with test data, including first name, last name, email, and contact number, and submit the form. This action will send the data to Pabbly Connect.
Return to your Pabbly Connect dashboard, where you will see that it is waiting for a webhook response. After submitting the form, Pabbly Connect will capture the response, showing the submitted details such as first name, last name, email, and contact number. This confirms that the integration is working correctly.
4. Enrolling User in Zenlo Using Pabbly Connect
Now that we have successfully captured the webhook response, the next step is to set Zenlo as the action application in Pabbly Connect. Click on the action application dropdown and select Zenlo. Then, choose the action event labeled ‘Enroll User to a Course’. This action will enroll the user based on the data received from Elementor.
- Select Zenlo as the action application.
- Choose ‘Enroll User to a Course’ as the action event.
- Connect to your Zenlo account by entering the required API key and school account name.
To obtain your API key, log into your Zenlo account, navigate to settings, and find the API key under the developers section. Copy this key back to Pabbly Connect, along with your school account name, and save your settings. After this, you will need to map the course ID and user details such as email, first name, and last name to complete the enrollment process.
5. Verifying Enrollment Success in Zenlo
After mapping all necessary fields in Pabbly Connect, click on ‘Save and Send Test Request’ to finalize the enrollment action. If everything is set up correctly, you should receive a success message indicating that the user has been successfully enrolled in the specified course.
To verify, log into your Zenlo account, navigate to the course section, and check the enrollment list. You should see the test user you just enrolled. This confirms that the integration between Elementor and Zenlo via Pabbly Connect has been successfully completed. You can repeat the process with different test data to ensure consistent functionality.
This tutorial demonstrated how to integrate Elementor with Zenlo using Pabbly Connect. By following these steps, you can automate user enrollment seamlessly, enhancing your workflow and saving time. Utilize Pabbly Connect to simplify your integrations and make automation easy.
