Learn how to integrate Elementor with Trello using Pabbly Connect for seamless automation. This tutorial covers every step in detail. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To integrate Elementor with Trello, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect homepage by typing Pabbly.com/connect in your browser. On the homepage, you will see options to either sign in or sign up for free.
If you are a new user, click on the ‘Sign Up for Free’ button to create an account. Upon signing up, you will receive 100 free tasks each month, allowing you to explore the automation capabilities of Pabbly Connect effectively.
Once logged into Pabbly Connect, navigate to the ‘All Apps’ section and select ‘Pabbly Connect’. Click on the ‘Access Now’ button to enter the dashboard where you can manage your workflows. To create a new workflow, click on the ‘Create Workflow’ button located in the top right corner.
A dialog box will prompt you to name your workflow. For this integration, name it ‘Create Trello Card for Elementor Form Submission’ and select a folder to save it in. After naming, click on the ‘Create’ button, which will open two windows for trigger and action setup.
  • Select ‘Elementor’ as the trigger application.
  • Copy the provided webhook URL for later use.
These steps ensure that your workflow is set to capture form submissions from Elementor and use them in Trello via Pabbly Connect.
Setting Up Elementor Forms for Integration
Next, you need to set up your Elementor forms to connect with Pabbly Connect. Navigate to your WordPress site and select the Elementor option from the left sidebar. Click on ‘Getting Started’ and then on ‘Create Your First Page’ to access the form settings.
In the form settings, add a new item for collecting user contact numbers. After making these changes, scroll down to the ‘Actions After Submit’ section, click the plus sign, and select ‘Webhooks’. Paste the copied webhook URL from Pabbly Connect into the designated field and click on ‘Preview Changes’ to save your settings.
Testing the Integration with Pabbly Connect
With your Elementor form set up, it’s time to test the integration. Fill out your form with random details and submit it. After submission, return to Pabbly Connect to see if the response is captured successfully. You should see all the details you entered displayed in Pabbly Connect.
Once the response is confirmed, proceed to create a new card in Trello using the captured data. In the action step of Pabbly Connect, select Trello and choose the action event ‘Create Card’. Connect your Trello account by providing the username, API key, and token as instructed in Pabbly Connect.
  • Select the board where you want to create the card.
  • Choose the specific list for the new card.
  • Map the data from the form submission to the card fields.
After entering all necessary details, click on ‘Save and Send Test Request’. This will create the card in Trello with the mapped data, confirming that your automation is working seamlessly via Pabbly Connect.
Summary of Integration Steps
In this tutorial, we successfully integrated Elementor with Trello using Pabbly Connect. We started by accessing Pabbly Connect, creating a workflow, and setting up our Elementor forms. After testing our integration, we were able to create Trello cards automatically based on form submissions.
This automation process not only saves time but also enhances productivity by ensuring that every form submission is captured and acted upon efficiently. By following these steps, you can easily replicate this integration to streamline your workflow between Elementor and Trello using Pabbly Connect.
In conclusion, integrating Elementor with Trello through Pabbly Connect allows for efficient automation of tasks. By following the detailed steps provided, you can create seamless workflows that enhance productivity and organization.
