Learn how to integrate Elementor with Stackby using Pabbly Connect. This detailed tutorial covers every step to automate form submissions seamlessly. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To begin integrating Elementor with Stackby, first access Pabbly Connect by navigating to the official website. Once there, sign in to your existing account or create a new one to utilize the platform’s automation features.
After signing in, you will be directed to the Pabbly Connect dashboard. This interface allows you to manage all your workflows and integrations. Click on the ‘Create Workflow’ button to initiate a new integration process.
In Pabbly Connect, creating a workflow involves naming your project and selecting a folder. Name your workflow something descriptive, such as ‘Integrating Elementor Form Submissions to Stackby.’ Then, choose the appropriate folder where you want this workflow to be saved.
  • Name your workflow for clarity.
  • Select a folder to keep your workflows organized.
Once you have configured these settings, click on the ‘Create’ button. You will now see two sections: Trigger and Action. The Trigger is the event that starts the workflow, while the Action is what happens as a result.
3. Setting Up the Trigger with Elementor
To set up the trigger in Pabbly Connect, select Elementor as your application. Choose the event labeled ‘New Form Submission’ to capture data from your Elementor forms. This action will initiate the workflow whenever a form is submitted.
Next, you will be provided with a webhook URL. This URL acts as a bridge between Elementor and Pabbly Connect. Copy this URL and paste it into the webhook settings of your Elementor form. This step is crucial for ensuring that form submissions are sent to Pabbly Connect.
4. Configuring the Action in Stackby
After setting up the trigger, the next step is to configure the action in Stackby through Pabbly Connect. Select Stackby as the action application and choose the event ‘Create a Record’. This will allow you to add the submitted form data into your Stackby account automatically.
To establish a connection with Stackby, you will need to enter your API key. Copy the API key from your Stackby account and paste it into the required field in Pabbly Connect. After entering the key, click on ‘Save’ to establish the connection.
  • Select Stackby as the action application.
  • Choose the ‘Create a Record’ event.
  • Enter your Stackby API key to connect.
Once the connection is established, map the fields from your Elementor form to the corresponding fields in Stackby. This ensures that the data captured from the form is accurately recorded in your Stackby workspace.
5. Testing the Integration
Now that you have set up both the trigger and the action, it’s time to test your integration. Go back to your Elementor form and submit a test entry. Once submitted, check your Pabbly Connect dashboard to see if the response has been recorded successfully.
If the test submission is successful, you will see the data appear in your Stackby account as well. This confirms that your integration between Elementor and Stackby via Pabbly Connect is functioning correctly.
After verifying the success of the integration, you can continue using your Elementor forms to collect data, which will automatically populate in Stackby through Pabbly Connect. This automation saves time and ensures accurate data entry.
In this tutorial, we explored how to integrate Elementor with Stackby using Pabbly Connect. By following the steps outlined, you can automate form submissions and streamline your data management processes effectively.
