Learn how to integrate Elementor with Pluto using Pabbly Connect for seamless form submissions and contact management. Follow our detailed tutorial for easy automation. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To integrate Elementor with Pluto, we first need to access Pabbly Connect. You can do this by typing ‘Pabbly.com/connect’ in your browser. Here, you will find options to sign in if you are an existing user or sign up for free if you are new.
Once logged in, you will see the dashboard where you can create workflows. Click on the ‘Create Workflow’ option to start the integration process. This is where you will set up the connection between Elementor and Pluto using Pabbly Connect.
After accessing Pabbly Connect, click on ‘Create Workflow’. You will be prompted to name your workflow, such as ‘Create Pluto Person on Elementor Form Submission’. Choose the appropriate folder to save your workflow for better organization.
- Name your workflow clearly for easy identification.
- Select a folder for better management of multiple workflows.
Once named and saved, you will land on a screen with two main sections: Trigger and Action. Set the Trigger application to Elementor and the Action application to Pluto in this step. This setup is crucial as Pabbly Connect will automate the process based on the form submissions from Elementor.
In the Trigger section, select Elementor as your trigger application. The event you want to trigger is ‘New Form Submission’. This means that every time a form is submitted via Elementor, it will initiate the action in Pabbly Connect.
After selecting the trigger, you will receive a webhook URL. Copy this URL as it will be used to connect your Elementor form to Pabbly Connect. Log into your Elementor account and paste this webhook URL into the form settings under the Actions After Submit section.
- Log into your Elementor account and navigate to your form.
- In the Actions After Submit section, select Webhook and paste the copied URL.
After saving the changes in Elementor, your trigger setup is complete, and Pabbly Connect is ready to receive data from your form submissions.
Now that your trigger is set, it is time to test the integration. Go back to Pabbly Connect and click on ‘Test Webhook’. Submit a test form on your Elementor page with sample data. Ensure to include all the fields like name, email, and gender.
After submitting the form, return to Pabbly Connect to see if the response is captured. You should see all the submitted data reflected in the response section, confirming that the integration is working successfully.
Submit a test form with dummy data to check if the webhook captures the response. Verify that all fields, including custom fields, are visible in Pabbly Connect.
If the test is successful, proceed to set up the action to create a new contact in Pluto using the captured data.
5. Creating a Contact in Pluto via Pabbly Connect
In the Action section of Pabbly Connect, select Pluto as your action application. Choose the action event ‘Create Person with Custom Fields’. This step is crucial as it will add the form submitter as a contact in Pluto.
Next, you will need to connect your Pluto account by entering the required credentials such as client ID and client secret. These can be obtained from your Pluto account settings. Once connected, map the fields from the Elementor response to the respective fields in Pluto, including custom fields like gender.
Select the action event to create a new person in Pluto. Map the necessary fields from the Elementor form response to Pluto.
After setting this up, click ‘Save and Send Test Request’ to ensure that the person is created in Pluto. You can verify this by checking your Pluto contacts to see if the new entry appears.
In this tutorial, we demonstrated how to integrate Elementor with Pluto using Pabbly Connect. By following these steps, you can automate the process of adding new contacts based on form submissions, enhancing your workflow without any coding skills. This integration allows for seamless data management and personalized client interactions.
