Learn how to integrate Elementor with Notion using Pabbly Connect in this detailed tutorial. Streamline your lead management process effortlessly. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To integrate Elementor with Notion, the first step is accessing Pabbly Connect. Open your browser and visit the Pabbly Connect landing page by searching for ‘Pabbly.com/connect’.
Once on the landing page, you will see options for signing in or signing up. If you are a new user, click on ‘Sign up for free’. Existing users can simply click on ‘Sign in’ to access their accounts. After signing in, you will be directed to your dashboard where you can create workflows.
After accessing your dashboard, click on the ‘Create Workflow’ button. You will be prompted to name your workflow, so enter a name like ‘Elementor to Notion Integration’ and choose a folder to save it in. using Pabbly Connect
  • This will open the workflow window, where you can set up triggers and actions.
In the workflow window, select ‘Elementor’ as your trigger application. This means that the workflow will activate when a new form submission is made in Elementor. Next, choose ‘New Form Submission’ as the trigger event, which starts the workflow whenever a new lead is submitted.
3. Setting Up Webhook in Elementor
Once you have selected the trigger event, Pabbly Connect will provide you with a webhook URL. Copy this URL, as you will need it to connect Elementor with Pabbly Connect.
Now, go to your Elementor account. Navigate to the form you wish to integrate and click on the ‘Edit with Elementor’ button. In the form settings, locate the ‘Actions After Submit’ section and add a new action as ‘Webhook’. Paste the copied webhook URL here.
  • Make sure to click on ‘Publish’ to save your changes.
  • This step is crucial for ensuring that your Elementor form can send data to Pabbly Connect.
After publishing, your Elementor form is now connected to Pabbly Connect, and you should see a message indicating that it is waiting for a webhook response.
4. Testing the Webhook Connection
To test the webhook connection, you need to submit a test form using the Elementor form you just set up. Enter test details such as first name, last name, email, and property type, and then click on the ‘Send’ button. using Pabbly Connect
Once the test submission is successful, go back to your Pabbly Connect workflow and check if the response from Elementor has been captured. You should see the details you entered in the previous step, confirming that the webhook is working as intended.
This step ensures that your integration is functioning correctly before proceeding. You will see all the captured details in the Pabbly Connect interface.
Now that you have successfully tested the webhook, you are ready to move on to the action step of your workflow.
5. Integrating Notion with Pabbly Connect
For the action application, select ‘Notion’ in your Pabbly Connect workflow. Choose ‘Create Database Item’ as the action event, which allows you to add the form submission details to your Notion database.
Next, you will need to connect your Notion account with Pabbly Connect. Click on ‘Connect’ and follow the prompts to authorize Pabbly Connect to access your Notion account. Make sure to grant permissions for the specific pages you want to connect.
Select the database where you want to add the new lead details, such as ‘New Leads’. Map the fields from the Elementor form submission to the corresponding fields in Notion.
Finally, click on ‘Send Test Request’ to verify that the data is being correctly added to your Notion database. After confirming the successful addition, you can now automate the entire lead management process using Pabbly Connect.
In this tutorial, we demonstrated how to integrate Elementor with Notion using Pabbly Connect. By following these steps, you can streamline your lead management process, ensuring that every form submission is efficiently captured and organized in Notion.
This integration not only saves time but also enhances your ability to follow up with potential clients effectively. With Pabbly Connect, managing your leads has never been easier!
