Learn how to automate lead management by integrating Elementor with Go High Level using Pabbly Connect. Step-by-step tutorial included. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start integrating Elementor with Go High Level, you need to access Pabbly Connect. This powerful automation tool allows you to connect different applications seamlessly. First, visit the Pabbly Connect website and log into your existing account or sign up for a free account if you are a new user.
After signing in, you will see the Pabbly Connect dashboard. Here, you can create workflows that automate tasks between applications. To initiate the integration process, click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
In this section, we will create a specific workflow to automate lead management. First, you need to name the workflow. For this integration, name it ‘Create or Update Go High Level Contact on Elementor Form Submission’. Choose a folder to save this workflow, such as ‘Elementor Automations’.
- Select the folder where you want to save the workflow.
- Click on the ‘Create’ button to finalize the workflow setup.
Once the workflow is created, you will see two sections: Trigger and Action. The trigger will initiate the automation process, while the action defines what happens after the trigger. This is essential for setting up the connection between Elementor and Go High Level through Pabbly Connect.
Here, we will set up the trigger for our workflow. The trigger application will be Elementor, which is a popular website builder for WordPress. Select ‘Elementor’ as the trigger application and choose ‘New Form Submission’ as the trigger event.
After selecting the trigger event, Pabbly Connect will provide you with a unique webhook URL. This URL will be used to connect your Elementor form to Pabbly Connect. Copy this webhook URL and navigate to your Elementor form settings.
- In Elementor, go to the form settings and find the ‘Actions After Submit’ section.
- Add a new action and select ‘Webhook’.
- Paste the copied webhook URL into the designated field.
After saving your changes, return to Pabbly Connect to check the workflow status. It should say ‘Waiting for Webhook Response’, indicating that the connection is ready to capture form submissions.
4. Testing the Connection in Pabbly Connect
Now that the trigger is set up, it’s time to test the connection. To ensure that the integration works, perform a test form submission using the Elementor form you have connected. Fill in the required fields such as first name, last name, email, and phone number, then click on the send button.
Once you submit the form, return to Pabbly Connect and check if the webhook response has been captured. You should see the data from your test submission displayed in the workflow. This confirms that Elementor is successfully sending data to Pabbly Connect.
If the data appears correctly, it means that the trigger setup is complete. Now, every time a new form submission occurs, Pabbly Connect will automatically capture the response, ensuring no leads are missed.
5. Setting Up the Action in Pabbly Connect
With the trigger successfully set up, we will now configure the action that occurs when a form submission is captured. For the action application, select ‘Lead Connector V2’, which is the integration for Go High Level. Choose ‘Create or Update Contact’ as the action event.
After selecting the action, click on the connect button to link your Go High Level account with Pabbly Connect. You will need to authorize the connection by selecting the sub-account where you want to create the new contact.
Map the fields from the previous step to the action fields. For the first name, last name, email, and phone number, select the corresponding data from the Elementor form submission. Click on ‘Save and Send Test Request’ to finalize the action setup.
After completing these steps, check your Go High Level account to confirm that the new contact has been created with the details from the Elementor form submission. This confirms that the automation between Elementor and Go High Level via Pabbly Connect is successful.
This tutorial demonstrates how to integrate Elementor with Go High Level using Pabbly Connect. By automating lead management, businesses can save time and reduce data entry errors. Now, every new form submission on Elementor will automatically create or update contacts in Go High Level, streamlining the entire process.
