Learn how to automate subscriber management by integrating Elementor Forms with Flowdesk using Pabbly Connect in this detailed tutorial. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To begin using Pabbly Connect, first, create an account by clicking on the free sign-up link provided in the description. This allows you to set up your automation workflows quickly.
After signing up, navigate to the Pabbly Connect dashboard. Here, click on ‘Create Workflow’ and name your workflow, for instance, ‘Elementor to Flowdesk’. This sets the stage for your integration process.
The next step involves setting up the trigger in Pabbly Connect. In the trigger window, select ‘Elementor’ as your app. Then, choose the trigger event as ‘New Form Submission’. This allows Pabbly Connect to capture data from your Elementor form submissions.
  • Select Elementor from the app list.
  • Copy the generated webhook URL provided by Pabbly Connect.
Next, go to your Elementor form in edit mode. Click on the form, navigate to ‘Actions After Submit’, and select ‘Webhook’. Paste the copied URL into the webhook field and click on ‘Update’. This connects your Elementor form to Pabbly Connect.
3. Testing the Trigger Setup
Once your Elementor form is connected to Pabbly Connect, it’s time to test the trigger. Open the form in preview mode and submit a test entry with sample data, such as a name and email address. This action will send data to Pabbly Connect.
After submission, return to your Pabbly Connect dashboard. You should see that the trigger window is now displaying the details of the submitted form. This confirms that the connection is working correctly.
4. Setting Up the Action to Add Subscribers in Flowdesk
Now, we move to the action window in Pabbly Connect. Here, search for ‘Flowdesk’ and select it. Choose the action event as ‘Create/Update Subscriber’. This action enables you to add or update subscribers based on the form submissions captured earlier.
  • Select Flowdesk as the app.
  • Choose ‘Create/Update Subscriber’ as the action event.
  • Connect your Flowdesk account to Pabbly Connect.
After connecting, map the email, first name, and last name fields from the Elementor form submission to the corresponding fields in Flowdesk. This ensures that the subscriber information is correctly transferred every time a new form is submitted.
5. Finalizing the Automation Workflow
To complete the setup, save your changes in Pabbly Connect and test the action. Click on ‘Save and Send Test Request’ to verify that the subscriber is added to your Flowdesk account.
Check your Flowdesk account to confirm that the test subscriber appears in your audience list. If everything works correctly, you have successfully automated the process of adding subscribers from Elementor forms to Flowdesk using Pabbly Connect.
This tutorial has shown you how to seamlessly integrate Elementor Forms with Flowdesk using Pabbly Connect. By following these steps, you can automate subscriber management efficiently.
