Learn how to automate the enrollment of Thinkific users from Elementor form submissions using Pabbly Connect. Follow our detailed tutorial for seamless integration. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start using Pabbly Connect, visit the official website and sign in to your account. If you are new, you can sign up for free and get 100 tasks every month. This platform is essential for automating the integration between Elementor and Thinkific.
Once logged in, you will see the Pabbly Connect dashboard. Here, you can create workflows that will automate the enrollment of students from Elementor forms into Thinkific. This process saves time and reduces manual work significantly.
To create a new workflow in Pabbly Connect, click on the ‘Create Workflow’ button located in the top right corner of the dashboard. A dialog box will appear prompting you to name your workflow and select a folder to save it in.
- Name your workflow: ‘Enroll Thinkific User on Elementor Form Submission’.
- Select a folder, such as ‘Elementor Automations’.
After naming and selecting the folder, click the ‘Create’ button. You will then see two windows: one for the trigger and one for the action, which are crucial for setting up your automation.
3. Setting Up the Trigger with Elementor
For the trigger in Pabbly Connect, select Elementor as the application. Choose the ‘New Form Submission’ event to capture data from the form submissions on your website. This is the first step in automating the enrollment process.
After selecting Elementor, Pabbly Connect will provide you with a unique webhook URL. Copy this URL, as it will be used to connect Elementor with Pabbly Connect. Paste this URL into the action settings of your Elementor form to establish the connection.
4. Connecting Elementor to Pabbly Connect
To connect your Elementor form to Pabbly Connect, open the form settings in Elementor. Navigate to the ‘Actions After Submit’ section and add a new action by selecting ‘Webhook’. Paste the copied webhook URL into the designated field.
After saving the changes, test the connection by submitting a test form. Once the form is submitted, return to your Pabbly Connect workflow, and you should see that the response has been captured successfully, confirming the integration is working.
5. Enrolling Users in Thinkific
With the trigger set, the next step is to enroll the user in Thinkific through Pabbly Connect. For the action application, select Thinkific and choose the ‘Create User’ event. This action allows you to add the new student to your Thinkific account.
When setting up this action, you will need to map the data from the previous step (Elementor form submission) to the required fields in Thinkific. This includes the student’s first name, last name, and email. Ensure that all fields are accurately filled to create the user successfully.
Finally, after mapping the data, click the ‘Save and Send Test Request’ button. If successful, you will receive a confirmation that the user has been added to your Thinkific account. You can then proceed to enroll the user in the desired course.
Using Pabbly Connect allows you to seamlessly integrate Elementor with Thinkific, automating the enrollment process for your courses. This tutorial covered the steps to create a workflow, set triggers, and enroll users efficiently. Automate your processes today with Pabbly Connect!
