Learn how to automate your Elementor form submissions to create contacts in Pluto using Pabbly Connect. Follow our detailed tutorial for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To begin the integration process, access Pabbly Connect by navigating to its website. If you are a new user, click on the ‘Sign Up for Free’ button to create your account. Existing users can simply sign in.
Once logged in, you will be directed to the dashboard where you can create new workflows. Here’s how to get started:
  • Click on ‘Create Workflow’.
  • Name your workflow, e.g., ‘Create Pluto Person on Elementor Form Submission’.
Now that you have set up your workflow, you are ready to connect Elementor and Pluto using Pabbly Connect.
2. Setting Up Elementor as Trigger in Pabbly Connect
In this section, you will configure Elementor as the trigger for your workflow in Pabbly Connect. Choose Elementor as the trigger application and select the event ‘New Form Submission’.
After selecting the trigger, Pabbly Connect will provide you with a webhook URL. This URL is essential for transferring data from Elementor to Pabbly Connect. Follow these steps:
  • Log into your Elementor account and create a form with custom fields.
  • In the form settings, go to ‘Actions After Submit’ and select ‘Webhook’. Paste the copied URL here.
Once the webhook is set up, your Elementor form will successfully send submissions to Pabbly Connect.
3. Testing Elementor Connection with Pabbly Connect
With your Elementor form configured, it’s time to test the connection to ensure data is being received by Pabbly Connect. Submit a test form with dummy data, including the custom fields you set up.
After submitting the form, return to Pabbly Connect. You should see the response captured in the dashboard, confirming that the integration is successful. The data will include:
Name of the person Email address Phone number Gender
This step ensures that whenever a new form is submitted via Elementor, the data will be sent to Pabbly Connect for further processing.
4. Creating a Contact in Pluto Using Pabbly Connect
Now that the connection between Elementor and Pabbly Connect is established, you can set up Pluto as the action application. Choose Pluto and select the action event ‘Create Person with Custom Fields’.
To connect Pluto with Pabbly Connect, you will need your Client ID, Client Secret, and Business Identifier. These can be found in your Pluto account under API settings. Follow these steps to complete the connection:
Enter your Business Identifier, which is your subdomain. Copy and paste your Client ID and Client Secret from Pluto. Click ‘Save’ to establish the connection.
Once connected, Pabbly Connect will allow you to map the data received from Elementor to create a new contact in Pluto.
With both Elementor and Pluto set up in Pabbly Connect, you can now finalize the integration. Map the fields from the Elementor response to the corresponding fields in Pluto, ensuring that all necessary information is included.
To test the integration, submit another form through Elementor. Check your Pluto account to confirm that the contact has been created with the correct details. This step validates that your workflow is functioning correctly:
Ensure the name, email, and gender are correctly mapped. Verify that the contact appears in your Pluto account. Repeat the test with different data to ensure reliability.
After validating the integration, you can confidently use Pabbly Connect to automate the process of adding new contacts from Elementor to Pluto.
This tutorial has detailed how to integrate Elementor with Pluto using Pabbly Connect. By following these steps, you can streamline your client registration process efficiently.
