Learn how to seamlessly integrate ClickFunnels with WooCommerce using Pabbly Connect to automate customer creation. Step-by-step guide included. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To integrate ClickFunnels with WooCommerce, you need to access Pabbly Connect. Start by visiting the Pabbly website and navigating to the Pabbly Connect section.
Once on the homepage of Pabbly Connect, you can either sign in if you are an existing user or sign up if you are new. Signing up takes just a couple of minutes, and you will receive 100 free tasks to test your automations. After signing in, click on the ‘Access Now’ button for Pabbly Connect.
After accessing Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button located on the right-hand side of the dashboard. using Pabbly Connect
  • Name your workflow, for example, ‘Add New ClickFunnels Contacts to WooCommerce as Customers’.
  • Select a folder if you have multiple folders.
This will lead you to a new window with two crucial events: Trigger and Action. The trigger will be ClickFunnels, and the action will be WooCommerce, setting the stage for your automation.
3. Setting Up ClickFunnels Trigger in Pabbly Connect
For the integration, the trigger application is ClickFunnels. Click on the ClickFunnels option and select the event as ‘New Contact Created’. This event will initiate the workflow. using Pabbly Connect
Pabbly Connect will provide you with a webhook URL. Copy this URL as it will serve as a bridge between ClickFunnels and Pabbly Connect. Next, navigate to your ClickFunnels account, go to Settings, and find the Webhooks section.
  • Click on ‘Add New Endpoint’.
  • Paste the copied webhook URL.
  • Set the event type to ‘Contact Created’ and click ‘Create Endpoint’.
Once the endpoint is created, return to Pabbly Connect, which will now wait for a webhook response from ClickFunnels.
4. Testing the Integration with ClickFunnels
To test the integration, you need to create a new contact in ClickFunnels. Fill out the form with the necessary details like first name, last name, email address, and mobile number. After submitting the form, return to Pabbly Connect. using Pabbly Connect
Pabbly Connect will display the webhook response containing the details of the new contact. This confirmation indicates that the integration is receiving data correctly. The next step is to set up WooCommerce as the action application.
Select WooCommerce as the action application. Choose the action event as ‘Add New Customer’. Click on ‘Connect’ to establish the connection.
After connecting, you will need to provide WooCommerce with the necessary credentials to create a new customer.
5. Configuring WooCommerce Credentials in Pabbly Connect
To configure WooCommerce within Pabbly Connect, you will need the consumer key, consumer secret, and website URL. These can be obtained from your WooCommerce settings under the REST API section.
Once you have this information, return to Pabbly Connect and paste the consumer key and secret in the respective fields. Also, enter your website URL and click ‘Save’. This will establish a connection between WooCommerce and Pabbly Connect.
Map the email address, first name, last name, and other required fields using the mapping feature. Fill in any optional fields as necessary. Click ‘Save and Send Test Request’ to create the customer in WooCommerce.
After saving, check your WooCommerce customer list to confirm that the new customer has been successfully added. This completes the integration process using Pabbly Connect.
In conclusion, integrating ClickFunnels with WooCommerce using Pabbly Connect allows for seamless customer management. This automation saves time and ensures that every new contact is efficiently added as a customer.
