Learn how to seamlessly integrate Cashfree Payments with Zoho Campaigns using Pabbly Connect to automate subscriber updates efficiently. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start integrating Cashfree Payments with Zoho Campaigns, you need to access Pabbly Connect. Begin by visiting the Pabbly Connect website, where you can either sign in as an existing user or sign up for a free account.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will find the option to create a new workflow. Click on the ‘Create Workflow’ button to begin setting up the integration between Cashfree Payments and Zoho Campaigns.
In this section, you will create a workflow that triggers when a payment is made through Cashfree. After clicking on ‘Create Workflow’, name your workflow something like ‘Add or Update Zoho Campaign Subscriber on Cashfree Payment’ and select the appropriate folder.
  • Click on ‘Create’ to open the workflow window.
  • Select ‘Cashfree’ as the trigger application.
  • Choose ‘Payment via Form’ as the trigger event.
After selecting the trigger event, you will receive a webhook URL. Copy this URL as it will be used to connect Cashfree Payments with your Pabbly Connect workflow. This URL is essential for ensuring that your payment data is sent to Pabbly Connect whenever a transaction occurs.
3. Setting Up Cashfree for Webhooks
Now that you have the webhook URL from Pabbly Connect, log into your Cashfree account. Navigate to the Developers section, select Payment Gateway, and then go to Webhooks. Here, you will add the webhook URL you copied earlier.
  • Click on ‘Add Webhook Endpoint’.
  • Paste the webhook URL and click on ‘Test Add’.
  • Confirm that the status shows success.
Once the webhook is successfully added, you can test it by making a sample payment. This will allow Pabbly Connect to capture the response from Cashfree, ensuring that your integration is working correctly.
4. Integrating Zoho Campaigns with Pabbly Connect
After confirming that Cashfree is set up correctly, return to your Pabbly Connect workflow. Select Zoho Campaigns as the action application and choose the action event as ‘Add or Update Subscriber’. This step is crucial as it ensures that every time a payment is made, the subscriber’s information is updated or added to your Zoho Campaigns account.
You will need to connect your Zoho Campaigns account by entering your domain. This domain is typically found in the URL of your Zoho Campaigns account. After entering the domain, click on ‘Connect with Zoho Campaign’ and authorize the connection.
5. Mapping Data Between Cashfree and Zoho Campaigns
Once the connection to Zoho Campaigns is established, you will need to map the subscriber details from Cashfree to Zoho Campaigns. This involves selecting the list where you want to add or update the subscriber and filling in the required fields such as email, first name, and last name.
Map the email field from the Cashfree response. Use the text formatter tool in Pabbly Connect to split full names into first and last names. Map the phone number as well, ensuring all necessary details are included.
After mapping all the fields, test the workflow to confirm that a new subscriber is added to Zoho Campaigns whenever a payment is made via Cashfree. This seamless integration allows for efficient email marketing and subscriber management through Pabbly Connect.
This tutorial demonstrated how to integrate Cashfree Payments with Zoho Campaigns using Pabbly Connect. By following these steps, you can automate the process of adding or updating subscribers, ensuring your email marketing efforts are always up to date.
