Learn how to automate the creation or update of MailerLite subscribers through Cashfree Payments using Pabbly Connect in this detailed tutorial. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
1. Introduction to Pabbly Connect for Cashfree and MailerLite Integration
Pabbly Connect is the central platform that enables the integration of Cashfree Payments with MailerLite. In this tutorial, we will explore how to automate the creation or update of subscribers in MailerLite whenever a payment is made through Cashfree. This integration streamlines your email marketing efforts by ensuring that every payment made results in an updated subscriber list. using Pabbly Connect
To get started, you will need to access your Pabbly Connect account. If you are new to Pabbly Connect, simply sign up for a free account and log in. Once logged in, you can create a new workflow that connects Cashfree and MailerLite seamlessly.
2. Creating a Workflow in Pabbly Connect for Cashfree Payments
To create a workflow in Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of your dashboard. You will be prompted to name your workflow; for this integration, you can name it ‘Create or Update MailerLite Subscriber on Cashfree Payment’. Choose a folder to keep your workflows organized. using Pabbly Connect
- Click on ‘Create’ to start building your workflow.
- Set the trigger application as Cashfree.
- Select ‘Payment via Form’ as the trigger event.
After setting up the trigger, you will receive a webhook URL from Pabbly Connect. This URL needs to be added to your Cashfree account to capture payment notifications. Make sure to copy this URL before proceeding to your Cashfree account.
3. Configuring Cashfree to Trigger Pabbly Connect
Log into your Cashfree account and navigate to the developer section. Under the payment gateway settings, find the webhook options. You will need to add a new webhook endpoint using the URL you copied from Pabbly Connect. This step ensures that Cashfree sends payment notifications to Pabbly Connect whenever a payment is made. using Pabbly Connect
To add the webhook, select ‘Payment Form’ and click on the ‘Add Webhook Endpoint’ button. Paste the copied webhook URL and test it to ensure that Cashfree can successfully send data to Pabbly Connect. A successful test response will confirm that the integration is set up correctly.
Once the webhook is added and tested, you can return to Pabbly Connect to proceed with the next steps of the integration. This connection allows Pabbly Connect to receive payment data from Cashfree whenever a transaction occurs.
4. Setting Up MailerLite Integration with Pabbly Connect
With Cashfree configured to trigger Pabbly Connect, the next step is to set up MailerLite as the action application. In your Pabbly Connect workflow, select MailerLite and choose the action event as ‘Create or Update Subscriber’. This ensures that whenever a payment is received, the customer who made the payment will be added or updated in your MailerLite subscriber list. using Pabbly Connect
- Connect your MailerLite account by entering the API token obtained from the MailerLite integrations page.
- Map the subscriber’s email, name, and phone number from the Cashfree payment data.
- Set the status of the subscriber to active to ensure they receive communications.
After mapping the necessary fields, click on ‘Save and Send Test Request’ to verify that the integration works correctly. A successful response indicates that a new subscriber has been created or updated in MailerLite based on the payment received through Cashfree.
5. Testing the Integration Between Cashfree and MailerLite
To ensure everything is working correctly, perform a test payment using your Cashfree payment form. Fill in the required details such as email, name, and phone number, and complete the payment process. Once the payment is confirmed, check your MailerLite account to see if the new subscriber has been added successfully.
Refreshing your MailerLite subscriber list should show the new entry with the details you provided during the test payment. This confirms that the integration between Cashfree and MailerLite through Pabbly Connect is functioning as intended. By automating this process, you save time and enhance your email marketing efficiency.
With this setup, every payment made through Cashfree will automatically update your MailerLite subscriber list, keeping your audience engaged without manual intervention.
In this tutorial, we explored how to integrate Cashfree Payments with MailerLite using Pabbly Connect. By automating the creation and updating of subscribers, you can streamline your email marketing efforts and enhance customer relationships. This integration ensures that every payment leads to an updated subscriber list, saving you time and effort in managing your email campaigns.
