Learn how to automate your email marketing by integrating Cashfree Payments with AWeber using Pabbly Connect. Follow this step-by-step tutorial for seamless automation. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin the integration process, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in to your account. If you are a new user, you can sign up for free and access 100 free tasks each month.
Once logged in, you will see the dashboard where all Pabbly applications are listed. Click on the ‘Access Now’ button under Pabbly Connect to proceed with creating your workflow.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of the dashboard. A dialog box will appear prompting you to name your workflow and select a folder for it.
- Name your workflow: ‘Create AWeber Subscriber on Cashfree Payment’.
- Select the folder: Choose ‘Cashfree Automations’ from the dropdown.
- Click the ‘Create’ button to finalize your workflow.
This action will create a new workflow in Pabbly Connect with two main sections: Trigger and Action. The Trigger is the event that starts the automation, while the Action is what happens in response to that trigger.
For the Trigger in your workflow, select ‘Cashfree’ as the application. The Trigger event should be set to ‘Payment via Form’. This will allow Pabbly Connect to capture payment responses from Cashfree.
Next, you will receive a unique webhook URL from Pabbly Connect. Copy this URL and log in to your Cashfree account. Navigate to the ‘Developers’ section and select ‘Webhooks’ under Payment Gateway.
- Click on ‘Add Webhook Endpoint’.
- Paste the copied webhook URL.
- Click on ‘Test and Add’ to confirm the connection.
Once the webhook is successfully added, you can return to Pabbly Connect and proceed to test the connection by making a test payment.
After successfully setting up the Trigger, it’s time to configure the Action. Select ‘AWeber’ as the application for the Action step and choose the event ‘Add or Update Subscriber’. This will allow you to automatically add customers as subscribers in your AWeber account.
Click the ‘Connect’ button to establish a connection between Pabbly Connect and AWeber. You will need to authorize Pabbly Connect to access your AWeber account. Once authorized, select the appropriate List ID where subscribers will be added.
Map the subscriber’s full name from the Cashfree payment response. Map the email address of the customer. Select options to update existing subscribers if necessary.
After filling in all required fields, click on ‘Save and Send Test Request’ to finalize the setup. This will ensure that the integration works correctly and the customer is added as a subscriber in AWeber.
To ensure the integration works, perform a test payment using the Cashfree payment form. Fill in the required fields such as name, email, and payment details. Once the payment is completed, return to Pabbly Connect to check if the payment response is captured.
You should see the transaction details including the customer’s name, email, and payment status. This confirms that Cashfree has successfully communicated with Pabbly Connect.
Finally, check your AWeber account to verify that the new subscriber has been added. Refresh the subscribers list to see the newly added customer with all their details, confirming that the integration between Cashfree and AWeber through Pabbly Connect is successful.
In this tutorial, we demonstrated how to integrate Cashfree Payments with AWeber using Pabbly Connect. This automation streamlines the process of adding new customers to your email list, enhancing your marketing efforts.
