Learn how to automate student enrollment in Graphy after Cashfree payments using Pabbly Connect. Follow this detailed tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To begin integrating Cashfree and Graphy, first access Pabbly Connect. This platform allows seamless automation between various applications, making it essential for your workflow.
To get started, visit the Pabbly Connect website. If you already have an account, sign in. If not, you can easily create a new account for free, which includes 100 tasks each month.
2. Setting Up Your Workflow in Pabbly Connect
Once logged into Pabbly Connect, you need to create a new workflow. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
- Name your workflow: ‘Enroll Student in Graphy on Successful Cashfree Payments’.
- Select a folder for organization, such as ‘Cashfree Automations’.
- Click the ‘Create’ button to finalize your workflow setup.
After creating the workflow, you will see two sections: Trigger and Action. The Trigger is the event that starts the workflow, while the Action is what happens as a result.
3. Setting Up the Trigger with Cashfree
For your trigger, select Cashfree as the application. The trigger event you need is ‘New Payment’. This means every time a payment is successfully processed, it will trigger the workflow in Pabbly Connect.
Once selected, Pabbly Connect will provide you with a unique webhook URL. Copy this URL to connect Cashfree with your Pabbly Connect workflow.
- Log into your Cashfree account and navigate to the ‘Developers’ section.
- Click on ‘Webhooks’ and then ‘Add Webhook Endpoint’.
- Paste the webhook URL from Pabbly Connect and select the latest version.
After saving the webhook, test it to ensure it captures responses correctly. You should receive a test response in Pabbly Connect, confirming the connection.
4. Setting Up the Action with Graphy
With your trigger set up, it’s time to configure the action. Select Graphy as your action application and choose the action event ‘Create Learner’. This step will enroll the student into the course upon successful payment. using Pabbly Connect
To connect Graphy, you will need to provide the API Key and Merchant ID. These can be found in your Graphy account under the Integrations section. Copy and paste them into the corresponding fields in Pabbly Connect.
Map the email, name, and phone number fields from the Cashfree payment response. Set a default password for the new learner, such as ‘password123’.
After filling in the required details, click ‘Save and Send Test Request’. Check your Graphy account to verify that the learner has been successfully created.
5. Enrolling the Learner into the Course
Now that the learner is created, the next step is to enroll them into the specific course they purchased. In Pabbly Connect, add another action step and select Graphy again, this time choosing the action event ‘Enroll Learner to a Course’.
For this action, map the learner’s email and provide the course URL from your Graphy account. This ensures that the correct course is assigned to the learner based on their payment.
Retrieve the course URL from the Graphy dashboard. Click ‘Save and Send Test Request’ to finalize the enrollment process.
Once completed, check your Graphy account again to confirm that the learner has been added to the course. This integration through Pabbly Connect automates the entire enrollment process, saving you time and effort.
In this tutorial, we demonstrated how to use Pabbly Connect to automate student enrollment in Graphy after successful Cashfree payments. By following these steps, you can streamline your workflow and enhance the learning experience for your students.
