Learn how to integrate Brilliant Directories with Go High Level using Pabbly Connect. Step-by-step tutorial on automating contact creation from form submissions. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To start integrating Brilliant Directories with Go High Level, you need to access Pabbly Connect. This platform allows you to automate tasks between various applications seamlessly. Begin by visiting the Pabbly Connect homepage and either signing in or signing up for a free account.
Once logged in, you will see the Pabbly Connect dashboard. Here, you can create workflows that enable the integration between your applications. This step is essential for automating the contact creation process for every new form submission.
The next step is to create a workflow in Pabbly Connect. Click on the ‘Create Workflow’ button found at the top right corner of the dashboard. You will be prompted to name your workflow. For this integration, name it ‘Create Go High Level Contact on Brilliant Directories Form Submission’.
- Select the folder for your workflow, e.g., ‘Automations’.
- Click on the ‘Create’ button to finalize your workflow creation.
With the workflow created, you can now set up a trigger that will initiate the process whenever a new lead is submitted through your Brilliant Directories form.
In this step, you will configure the trigger in Pabbly Connect. Select ‘Brilliant Directories’ as your trigger application and choose ‘Custom Webhook’ as the trigger event. This allows you to connect your Brilliant Directories form to Pabbly Connect effectively.
After selecting the trigger event, you will receive a webhook URL. Copy this URL, as it will be used to connect your Brilliant Directories account. Navigate to your Brilliant Directories account and go to the Developer Hub to create a new webhook using this URL.
4. Configuring Go High Level Integration in Pabbly Connect
After setting up your trigger, it’s time to configure the action in Pabbly Connect. Select ‘Lead Connector V2’ as your action application. This application is crucial for creating contacts in your Go High Level account.
Choose ‘Create a Contact’ as the action event. You will then need to connect your Go High Level account with Pabbly Connect by clicking on the ‘Connect’ button. Ensure you are logged in to your Go High Level account to facilitate this connection.
- Map the fields from the Brilliant Directories submission to the corresponding fields in Go High Level.
- Enter required details such as full name, email, and phone number.
Once the mapping is complete, click on the ‘Save and Send Test Request’ button to test the integration. This will send a test contact to your Go High Level account.
5. Testing the Integration
To ensure that your integration works correctly, perform a test submission on your Brilliant Directories form. Enter dummy data and submit the form. This action should trigger the workflow you set up in Pabbly Connect.
After submitting the form, check your Go High Level account to confirm that the new contact has been created successfully. If everything is set up correctly, you will see the new contact reflecting in your account.
This testing phase is crucial to verify that your automation is functioning as intended. If you encounter any issues, review the previous steps to ensure everything is correctly configured.
In this tutorial, we explored how to integrate Brilliant Directories with Go High Level using Pabbly Connect. By following the steps outlined, you can automate the creation of contacts based on form submissions, streamlining your lead management process effectively.
