Learn how to integrate Air, Make with Pabbly Connect for seamless automation. Follow this detailed tutorial to set up workflows effortlessly. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start integrating Air, Make with Pabbly Connect, you first need to access the platform. Visit the Pabbly Connect website by typing Pabbly.com/connect in your browser. Once there, sign in to your existing account or create a new one, which provides you with 100 free tasks monthly.
After logging in, you will be directed to the Pabbly Connect dashboard. From here, you can view all your workflows. If you want to create a new workflow, simply click on the ‘Create Workflow’ button. This action initiates the automation process between Air, Make, and other applications.
In this section, we will create a workflow to automate tasks between Air, Make, and Pabbly Connect. After clicking ‘Create Workflow’, you will be prompted to name your workflow. For example, name it ‘Integrate Air and Make with Pabbly Connect’. Then, select the folder where you want to save this workflow.
- Click on ‘Create’ to finalize your workflow name.
- You will see two boxes appear for Trigger and Action.
- Choose your trigger application, which is Air in this scenario.
Once the trigger is set, you can define the event that will initiate this workflow. For instance, selecting a new entry in Air will trigger the automation. This setup ensures that whenever there’s a new submission in Air, the workflow is activated through Pabbly Connect.
3. Setting Up the Air Trigger in Pabbly Connect
To set up the trigger, select Air as your application and choose the event type, such as ‘New Entry’. Click on ‘Connect’ to establish a connection with your Air account. If you are setting this up for the first time, you will need to authorize Pabbly Connect to access your Air account. using Pabbly Connect
After connecting, select the specific form you want to monitor for submissions. Once you’ve chosen the form, click on ‘Save and Send Test Request’. This action will prompt you to make a test submission in Air to capture the response data for mapping in the next steps.
4. Setting Up Action in Pabbly Connect
After successfully setting up the trigger with Air, the next step is to configure the action in Pabbly Connect. Choose the application you want to connect with, such as Make, and select the action event, like ‘Create Record’. Click on ‘Connect’ to link your Make account.
Once connected, you will need to map the data from the Air submission to the fields in Make. This includes mapping first name, last name, email, and phone number. After mapping the fields, click on ‘Save and Send Test Request’ to ensure the data is correctly sent to Make.
5. Finalizing Integration with Pabbly Connect
After successfully sending data to Make, the final step is to ensure that the information is also recorded in your desired location, such as a database or table. Choose the appropriate application for this step and set it up similarly by connecting it through Pabbly Connect.
Once everything is set up, you can perform a final test by submitting a new entry in Air to check if all data flows correctly through Pabbly Connect to Make and any other connected applications. This ensures that your automation is functioning as intended, providing seamless integration.
In this tutorial, we detailed how to integrate Air and Make using Pabbly Connect. By following the steps outlined, you can automate your workflows efficiently, saving time and reducing manual entry errors. This integration empowers users to streamline their processes effectively.
