Learn how to seamlessly integrate Air, Make, and Pabbly Connect through a detailed step-by-step tutorial. Automate your workflows without coding! Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start integrating Air, Make, and Pabbly Connect, first access Pabbly Connect by visiting its website. Simply type Pabbly.com/connect in your browser to reach the landing page.
Once there, sign into your Pabbly account. If you’re new, you can sign up for free to receive 100 tasks monthly. After logging in, navigate to the Pabbly Connect dashboard to create your first workflow for integration.
In the Pabbly Connect dashboard, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is where you will set up the automation process for integrating Air, Make, and Pabbly Connect.
- Click on ‘Create Workflow’.
- Name your workflow, e.g., ‘Integrate Air and Make with Pabbly Connect’.
- Select the folder for saving your workflow.
After naming the workflow, you will see two boxes labeled trigger and action. The trigger will be set to Air, while the action will be configured to Make, utilizing Pabbly Connect to facilitate this integration.
3. Setting Up Trigger for Air in Pabbly Connect
In this step, configure the trigger application as Air by selecting it from the dropdown menu. The trigger event will be set to ‘New Entry’, which means every time a new form submission occurs, it will initiate the workflow. using Pabbly Connect
Connect your Air account by clicking on ‘Add New Connection’ and authorize Pabbly Connect to access your Air data. Once connected, select the specific form you want to use for this automation.
- Choose the form from your Air account.
- Click on ‘Save and Send Test Request’ to capture the response.
This will allow Pabbly Connect to fetch the data from the form submissions, which will be used in the subsequent actions.
4. Setting Up Action for Make in Pabbly Connect
Next, set up the action application as Make. Select ‘Create Record’ as the action event. This will allow Pabbly Connect to create a new record in your Make account whenever a new entry is received from Air.
Connect your Make account by clicking on ‘Add New Connection’. Once authorized, map the fields from the Air submission to the corresponding fields in Make. For example, map the first name, last name, email, and phone number.
Map the fields accurately to ensure data consistency. Click ‘Save and Send Test Request’ to verify the action.
This step ensures that every new entry from Air is captured and recorded in Make, showcasing the powerful automation capabilities of Pabbly Connect.
5. Finalizing Integration and Testing in Pabbly Connect
After setting up both the trigger and action, it’s essential to test the entire workflow. Submit a new entry through Air to see if it correctly creates a record in Make using Pabbly Connect.
Check your Make account to confirm that the new entry appears as expected. This final step validates that the integration is functioning correctly and that Pabbly Connect is effectively automating your workflow.
Ensure that all mapped fields are populated correctly. Monitor the workflow to catch any errors during the process.
With this, you have successfully integrated Air and Make using Pabbly Connect, streamlining your data management process.
In this tutorial, we explored how to integrate Air and Make using Pabbly Connect. This powerful tool automates your workflows efficiently, ensuring seamless data transfer and management. With Pabbly Connect, you can enhance your productivity without any coding skills.
