Learn how to integrate WooCommerce and Stripe using Pabbly Connect. This detailed tutorial covers every step to create new Stripe customers from WooCommerce. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Accessing Pabbly Connect for WooCommerce and Stripe Integration
To start the integration process, you need to access Pabbly Connect. First, type ‘Pabbly.com’ in your browser and hit enter. Once on the Pabbly website, hover over the ‘Products’ tab and select ‘Connect’ from the dropdown menu.
Click on ‘Sign In’ to access your account. If you don’t have an account, you can create one for free. Pabbly Connect allows you to set up integrations without any coding skills, making it user-friendly for everyone.
Once you’ve logged into Pabbly Connect, click on ‘Create Workflow’. You will be prompted to name your workflow; for this integration, you can name it ‘WooCommerce to Stripe’. After naming it, click on ‘Create’.
This opens the trigger window. In the ‘Choose App’ section, select ‘WooCommerce’ and in the ‘Choose Method’, select ‘New Customer Created’. This trigger will initiate the integration whenever a new customer is added to WooCommerce.
3. Setting Up Webhooks in WooCommerce
Now, we need to set up webhooks in WooCommerce to send data to Pabbly Connect. Go to your WooCommerce settings, then click on ‘Advanced’ and select ‘Webhooks’. Click on ‘Add Webhook’ to create a new webhook.
Assign a name to your webhook (e.g., ‘New Customer Webhook’) and change the status from ‘Disabled’ to ‘Active’. In the ‘Topic’, select ‘Customer Created’. Copy the delivery URL from Pabbly Connect and paste it into the webhook settings in WooCommerce. Click on ‘Save Webhook’ to finalize the setup.
4. Capturing the Webhook Response
After saving the webhook, go back to Pabbly Connect and click on ‘Capture Webhook Response’. This allows Pabbly to wait for data from WooCommerce. To test this, create a dummy customer in WooCommerce.
Log out of your current profile, then register as a new customer. Fill in the required fields, including first name, last name, and email. Once registered, check Pabbly Connect to see if the customer data has been captured successfully.
  • Create a dummy customer in WooCommerce.
  • Check Pabbly Connect for captured data.
  • Ensure all necessary fields are filled.
Once the data is captured, you can proceed to sync it with Stripe.
5. Syncing WooCommerce Data with Stripe
To sync the captured data with Stripe, click on the plus button in Pabbly Connect to add an action step. Choose ‘Stripe’ as the app and ‘Create Customer’ as the action method. This will allow you to create a customer in Stripe based on the data received from WooCommerce.
Connect your Stripe account by entering the required API key. You can find this key in your Stripe account under the ‘Developers’ section. After connecting, map the fields from WooCommerce to the corresponding fields in Stripe, such as email, first name, and last name.
  • Select ‘Stripe’ and ‘Create Customer’ in Pabbly Connect.
  • Enter API key from Stripe.
  • Map customer details from WooCommerce to Stripe.
Finally, click on ‘Save and Send Test Request’ to create the customer in Stripe. You should see a confirmation that the customer has been successfully created.
In this tutorial, we demonstrated how to integrate WooCommerce and Stripe using Pabbly Connect. By following these steps, you can automate the process of adding new WooCommerce customers as Stripe customers effortlessly. This integration enhances your workflow and saves time by ensuring customer data is synchronized seamlessly.
