Learn how to integrate WooCommerce with Go High Level using Pabbly Connect for seamless automation of contacts and opportunities. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start integrating WooCommerce with Go High Level, you need to access Pabbly Connect. First, navigate to the Pabbly Connect dashboard by signing in or creating an account if you are a new user.
After logging in, you can explore the features of Pabbly Connect which allow you to automate tasks between different applications. This integration will enable you to create contacts and opportunities automatically whenever a new order is placed in WooCommerce.
To create a workflow in Pabbly Connect, click on the ‘Create Workflow’ button on the dashboard. Name your workflow something descriptive, like ‘Create Contact and Opportunity in Go High Level for WooCommerce Orders’.
- Choose WooCommerce as your trigger application.
- Select the trigger event as ‘New Order Created’.
Once you have set up the trigger, Pabbly Connect will provide you with a webhook URL. This URL will allow WooCommerce to send new order data to your Pabbly Connect workflow.
3. Setting Up WooCommerce to Send Data
Now, you need to configure WooCommerce to send data to Pabbly Connect. Go to your WordPress dashboard, navigate to WooCommerce settings, and click on the ‘Advanced’ tab. Here, you’ll find the option for webhooks.
- Click on ‘Add Webhook’ and enter a name for your webhook.
- Set the status to active and choose the topic as ‘Order Created’.
- Paste the webhook URL you copied from Pabbly Connect.
After saving the webhook, your WooCommerce store will now communicate with Pabbly Connect whenever a new order is created, allowing for real-time data transfer.
4. Testing the Integration with a New Order
To ensure that the integration works correctly, create a test order in WooCommerce. Add a product to the cart, proceed to checkout, and fill in the required details. Once you place the order, this action will trigger the workflow in Pabbly Connect.
Return to Pabbly Connect to check if the webhook has received the order data. You should see all relevant information, such as the customer’s name, email, and order details. This confirms that the integration between WooCommerce and Pabbly Connect is functioning properly.
5. Creating Contacts and Opportunities in Go High Level
After testing the integration, the next step is to set up actions in Pabbly Connect to create contacts and opportunities in Go High Level. Select ‘Lead Connector V2’ as your action application and choose ‘Create or Update Contact’ as the action event.
Map the fields from the WooCommerce order data to the corresponding fields in Go High Level, such as first name, last name, email address, and phone number. Once you have mapped all necessary fields, click on ‘Save and Send Test Request’ to create the contact.
Next, add another action step to create an opportunity. Again, select ‘Lead Connector V2’ and choose ‘Create or Update Opportunity’. Fill in the details such as opportunity name and status, and then save the request. This will ensure that both a contact and an opportunity are created in Go High Level every time an order is placed in WooCommerce.
In conclusion, this tutorial demonstrated how to integrate WooCommerce with Go High Level using Pabbly Connect. By following these steps, you can automate the creation of contacts and opportunities, streamlining your workflow and enhancing your business efficiency.
