Learn how to integrate WooCommerce orders with SendPulse subscribers using Pabbly Connect in this detailed step-by-step tutorial. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
Introduction to Pabbly Connect for WooCommerce and SendPulse
Pabbly Connect is an essential tool for integrating WooCommerce and SendPulse. This integration allows you to add new subscribers to SendPulse whenever a new order is created in WooCommerce. By using Pabbly Connect, you can automate this process without any coding knowledge.
WooCommerce is a popular platform for setting up online stores, while SendPulse is a powerful marketing automation software. Although WooCommerce and SendPulse have some native integration capabilities, they are limited. Therefore, using Pabbly Connect provides a more efficient solution for seamless integration.
Accessing Pabbly Connect for Integration Setup
To begin the integration, first, access Pabbly Connect by navigating to the Pabbly website. Here, you can sign in or create a free account if you don’t have one. Once logged in, you will be taken to the Pabbly Connect dashboard, where you can create your workflows.
Follow these steps to set up your integration:
  • Go to the Pabbly Connect dashboard.
  • Name your workflow (e.g., ‘WooCommerce to SendPulse’).
After naming your workflow, you can start integrating WooCommerce with Pabbly Connect by selecting WooCommerce as the app and setting the trigger method to ‘New Order Created.’ This setup will allow Pabbly Connect to listen for new orders in WooCommerce.
Configuring WooCommerce Webhook in Pabbly Connect
Once you have set the trigger in Pabbly Connect, the next step is to configure the webhook in WooCommerce. This webhook will send data to Pabbly Connect whenever a new order is created.
To set up the webhook, follow these specific steps:
  • Go to your WooCommerce account and navigate to Settings.
  • Click on the Advanced tab and select Webhooks.
  • Add a new webhook with the name ‘WooCommerce Integration’ and set the status to Active.
Paste the webhook URL provided by Pabbly Connect into the Delivery URL field and save the webhook. This configuration allows WooCommerce to communicate with Pabbly Connect whenever a new order is placed.
Sending Data to SendPulse Using Pabbly Connect
After capturing the webhook response in Pabbly Connect, the next step is to send this data to SendPulse. You will need to set SendPulse as the action app in Pabbly Connect.
To do this, follow these steps:
Select SendPulse as the action app in Pabbly Connect. Choose the action method as ‘Add Subscriber.’ Connect your SendPulse account by entering your API ID and Secret Key.
After connecting, map the relevant fields such as email and names from the WooCommerce order data to the SendPulse subscriber fields. This mapping ensures that the correct information is sent to SendPulse from Pabbly Connect.
Testing and Verifying the Integration
To ensure that the integration works as expected, you should test it by placing a new order in WooCommerce. Once the order is created, check Pabbly Connect to see if it captures the data correctly.
After placing the order, verify the following:
Check Pabbly Connect for the captured webhook response. Log into your SendPulse account and check if the new subscriber appears in your list.
This testing phase confirms that every time a new order is placed in WooCommerce, a new subscriber is automatically added to SendPulse through Pabbly Connect.
In this tutorial, we explored how to integrate WooCommerce with SendPulse using Pabbly Connect. By following the steps outlined, you can automate the addition of new subscribers in SendPulse whenever a new order is created in WooCommerce. This integration streamlines your marketing efforts and enhances customer engagement.
