Learn how to integrate WooCommerce with Razorpay using Pabbly Connect. Follow this detailed tutorial to automate customer creation for new orders. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start integrating WooCommerce with Razorpay, first access Pabbly Connect. This powerful integration platform allows you to connect different applications without needing any coding knowledge.
Open your web browser and navigate to the Pabbly Connect website. From the homepage, click on the ‘Connect’ option. If you don’t have an account, sign up for free to create your account in just 2 minutes. After signing in, you will be directed to the Pabbly Connect dashboard.
Once you are on the Pabbly Connect dashboard, the next step is to create a new workflow. Click on the ‘Create Workflow’ button and give your workflow a name, such as ‘V Commerce to Razorpay’. using Pabbly Connect
- Select WooCommerce as the application to connect.
After naming your workflow, select WooCommerce from the application list. In the method selection, choose ‘New Order Created’ as your trigger method. This setup indicates that every time a new order is created in WooCommerce, it will trigger the action in Razorpay.
3. Setting Up the Webhook for WooCommerce
To enable the integration, you will need to set up a webhook in WooCommerce. After selecting the trigger method, Pabbly Connect will provide a webhook URL. Copy this URL as you will need to paste it into WooCommerce. using Pabbly Connect
- Go to your WooCommerce settings.
- Navigate to the ‘Advanced’ tab and select ‘Webhooks’.
- Create a new webhook and paste the copied URL.
Ensure the webhook status is set to active and the topic is set to ‘Order Created’. Save the webhook settings in WooCommerce to finalize the setup.
4. Capturing the Webhook Response in Pabbly Connect
Now that your webhook is set up, return to Pabbly Connect and click on ‘Capture Webhook Response’. This action will allow Pabbly Connect to listen for incoming data from WooCommerce. using Pabbly Connect
Next, create a test order in WooCommerce to trigger the webhook. Go to your WooCommerce store, add a product to the cart, and proceed to checkout. Once the order is placed, Pabbly Connect should capture the webhook response, which includes customer details such as name, email, and contact number.
5. Integrating Razorpay with Pabbly Connect
With the webhook response captured, the next step is to integrate Razorpay. In Pabbly Connect, click on the plus button to add another action step. Select Razorpay and choose ‘Create Customer’ as the action method. using Pabbly Connect
To connect Razorpay, enter your API Key ID and Secret. You can find these credentials in your Razorpay dashboard under API settings. Map the customer details from the webhook response to the corresponding fields in Razorpay.
After filling in the required fields, click on ‘Save and Send Test Request’ to finalize the integration. If successful, you will see the new customer created in your Razorpay account, confirming that the integration is complete.
In this tutorial, we explored how to seamlessly integrate WooCommerce with Razorpay using Pabbly Connect. By following these steps, you can automate the process of adding customers to Razorpay whenever a new order is placed in WooCommerce. This integration enhances efficiency and streamlines your online business operations.
