Learn how to automate Wix Forms submissions to Riggy with Pabbly Connect. Step-by-step instructions for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To begin integrating Wix Forms with Riggy, you need to set up Pabbly Connect. First, sign up for a free account on the Pabbly Connect website. This platform allows you to create automation workflows between different applications, making the integration process seamless.
Once you have created your account and logged into the dashboard, click on the ‘Create Workflow’ button. Name the workflow (e.g., ‘Wix Form to Riggy’) and select the appropriate folder. This naming helps you identify your workflow later. After clicking ‘Create’, you will see the workflow interface with trigger and action windows.
In this step, you will set the trigger for your workflow using Pabbly Connect. Click on the trigger window and search for ‘Wix Forms’. Select it and choose the trigger event as ‘New Form Submission’ from the dropdown menu. This will allow Pabbly Connect to listen for new submissions.
  • Select ‘Wix Forms’ as the app.
Next, go to your Wix site editor. Navigate to the automation section and create a new automation. Choose to start from scratch, select Wix Forms as the trigger, and specify the form that will send data to Pabbly Connect. Paste the copied webhook URL in the target URL section and activate the automation.
3. Testing the Wix Form Submission
Now that you have set up the trigger, it’s time to test the integration using Pabbly Connect. Fill out the Wix form with test data, such as a name, email, and phone number. Once you submit the form, Pabbly Connect will receive this data through the webhook.
After submission, return to your Pabbly Connect workflow. You should see that a response has been captured in the trigger step, indicating that the form data has been successfully received. This confirms that the first part of your automation is set up correctly.
4. Setting Up the Action to Enroll Users in Riggy
The next step involves configuring the action in Pabbly Connect to enroll users in Riggy. In the action window, search for ‘Riggy’ and select it. Choose the action event as ‘Import User’ and click on connect to set up your Riggy account.
  • Select ‘Riggy’ as the app.
  • Choose ‘Import User’ as the action event.
  • Enter the API token from your Riggy account.
After connecting your account, map the fields from the trigger step to the action step. This includes the user’s full name, email, and phone number. Also, specify the product hash for the course you want to enroll the user in. Finally, select whether or not to send an email notification to the user upon enrollment.
5. Final Testing of the Automation
With everything set up, perform a final test of your automation using Pabbly Connect. Submit another test entry in your Wix form. After submission, check your Riggy account to confirm that the user has been added successfully.
This confirms that the entire automation workflow is functioning as intended. You can now automate the process of enrolling users in Riggy whenever a new form submission is received in Wix Forms. Enjoy the benefits of seamless integration and automation!
In this tutorial, we explored how to integrate Wix Forms with Riggy using Pabbly Connect. By following the steps outlined, you can automate user enrollment effectively. This integration enhances efficiency and saves time in managing form submissions.
